Update on fuel pump installation
Old Apr 24, 2016 | 10:18 AM
Black Ford XLT's Avatar
Black Ford XLT
As earlier I was having the problem of cranking my truck after hot humid weather using ac etc . This did not occur in fall winter or early spring .Course I know spring here it gets to 90 degrees .Truck is a 1985 F150 4x4 4.9 duraspark2 (computer gone thank goodness)heated cliffords intake , and the two barrel weber carb with regulator set at 3psi .I installed the redline fuel pump(noticed Clifford sells them with his kits now)and the symptoms of the no start when hot are gone .Seems my gas mileage has increased and when pulling long hills a steady smooth even rpm. Replys as the carb getting hot and boiling fuel from the bowl were taken into consideration. I installed the oil pump switch for safety and added a relay.Sure enough when july gets here the true test will show .Thanks TR
Old Apr 28, 2016 | 09:52 AM
ZarK-eh's Avatar
ZarK-eh
Awesome!
Oil Pump switch and relay, for the electric choke I presume?
Old Apr 28, 2016 | 11:37 AM
Black Ford XLT
Zark-eh, should of said oil pressure switch , in case of a roll over accident no oil pressure it cuts the fuel pump off!👍🏿 TR
Old Apr 29, 2016 | 04:00 PM
ZarK-eh's Avatar
ZarK-eh
That's a great idea!
FYI though, you could power an electric aftermarket choke with that. Original uses the alternator for power, but only puts out like 8 volts which aftermarket choke don't use.
Old Apr 29, 2016 | 11:51 PM
Black Ford XLT
I got it off a classic car site, they show the whole hookup, it's really an oil pressure safety switch 12 volt in 12 volt out to the coil of the relay where the contacts switch the fuel pump .On the, safety switch there's ignition and a stater hook up, actually feeds fuel when cranking . I used the air Tex os75. ,carter and a few other brand name has them . Good luck TR
kr98664
'80-'86 HOWTO's
29
Apr 19, 2019 06:36 PM
milkweed.gardener
Oct 25, 2018 07:38 PM
79f100six
Jan 3, 2008 01:38 AM
Warhorse86
Sep 14, 2004 09:46 AM
mositso
Sep 16, 2003 02:41 PM
