1995 Explorer front wheel bearing
Hi
I have a 1995 4wd Explorer. I have a noise in the front and upon inspection I found it needs a right front Wheel bearing.I have lookrf up the parts on line and found that you can buy the whole hub assembly or just the bearings.My question is do i need the whole assembley or, if the hub is fine can i just get the bearings.Also do i need a press to take them out?
flash041
flash041
toddncandy
11-16-2004 09:47 AM
