Hitch Brake Light Q ?
Old Jun 12, 2004 | 10:59 PM
Vinheyhey's Avatar
Vinheyhey
Got a Brake hitch Light with 4 pin plug ,all fit well after install but does not work ?? Is there something i have to do under the dash or on the truck to turn this option on ? Let me know if so . Thanks Vinnie M. 04 f-150 FX4 Crewcab.
Old Jun 12, 2004 | 11:47 PM
Steina's Avatar
Steina
CO River Rat
Check your owner's manual to see if there's a fuse just for trailer lights. Also, make sure the front end of your 4-pin harness is plugged in.
Steve
Old Jun 13, 2004 | 07:58 PM
rljphx's Avatar
rljphx
There was some sort of a relay that comes with trailer tow kit. It may need to be installed.
Old Jun 14, 2004 | 01:21 AM
Vinheyhey's Avatar
Vinheyhey
Thanks for the feedback Steina & rljphx , found the tow kit in the glove box ,installed the relay still does not work , will have the light checked out ,will post on the out come . Vinnie M.
Old Jun 14, 2004 | 02:42 AM
johnoconghaile's Avatar
johnoconghaile
i have one of the brake lights you refer to, umn dude check the bulb. nice brake light but its usually a cheap china made light bulb.
Old Jun 14, 2004 | 07:37 AM
RX 1 Liter's Avatar
RX 1 Liter
If it is a fuse good luck getting at it. I had to change my trailer turn signal fuses when both the left and right blew due to a short in the trailer. In Fords infinite wisdom they relocated the fuse box in the passenger side kick panel at a 90 degree angle. You have to contort your body (at 6'5" that isnt that easy) to be able to see the fuses. In my 97 they were conveniently located right under the steering wheel.
Old Jun 14, 2004 | 01:01 PM
zer0cool's Avatar
zer0cool
I'd suggest looking at the bulb also. i picked up a "Ford" lighted hitch cover at autozone, and all I did was plug it in. didn't have to mess with the wiring kit in the glove box or anything. I did cover up the few inches of exposed green and white wiring with electrical tape though.
Old Jun 14, 2004 | 08:34 PM
Vinheyhey's Avatar
Vinheyhey
Hey! Hey! Everyone thanks for the info , there was no bulb at all in the light , installed and now works , great thread works well !
Vinnie M.
Old Jun 14, 2004 | 08:42 PM
Steina's Avatar
Steina
CO River Rat
Vin -
I guess the bulb was optional at extra cost!!!
Steve
Old Jun 14, 2004 | 09:35 PM
rljphx's Avatar
rljphx
Glad its working now.
Buck Dharma Fan
Oct 24, 2014 05:04 PM
*2fords*
Jun 23, 2009 01:09 PM
VINNIE JAMES
1997 - 2003 F150
Jul 24, 2007 12:20 AM
Vinheyhey
2004 - 2008 F150
Apr 7, 2005 02:53 PM
vinny8
May 2, 2002 10:29 PM
