E4od leaks out front when towing
Old Jun 12, 2004 | 12:49 PM
garyd's Avatar
garyd
I've got a 1996 F150 that leaks out the front seal if I pull my camper on a long trip. If I drive without pulling the camper it does just fine . I have 70,000 miles on this truck. I was thinking the transmission is getting hot but wouldn't it blow out the breather also?? I was thinking of replacing the cooler with a bigger one. I work at Jasper Engines so I get a good deal on Hayden coolers. Should I think about replacing the radiator also?
Old Jun 15, 2004 | 11:50 AM
fulltroy's Avatar
fulltroy
I would check it for trouble codes before installing an additional cooler, if you have a factory tow package the cooler it came with will probably be better than aftermarket anyway. It sounds like the front seal is bad, when towing line pressure is higher and can cause leaks even if the tranny doesn't overheat. You'll need a front seal replaced no matter what along with the pump gasket. Nothing major usually, just bad seals.
billbot
Jan 13, 2014 09:29 AM
money pit 69
Dec 5, 2013 06:58 PM
BryanStein
Jul 27, 2013 01:52 PM
motocamper
Dec 11, 2012 12:21 PM
LEADSLED52
Aug 28, 2010 06:40 PM
