code p1309
Old Jan 14, 2003 | 08:25 PM
cecil's Avatar
cecil
code p1309
1998 explorer
5.0 engine
computer scan says code p1309
p1309 is misfire moniter aice chip fault
does any one know how to correct this
Old Jan 14, 2003 | 11:57 PM
Racerguy's Avatar
Racerguy
code p1309
A P1309 is a camshaft position sensor code. The manual says to hook up a breakout box and monitor the voltage from it. If it isnt right you replace the sensor.
Old Jan 15, 2003 | 07:30 AM
cecil's Avatar
cecil
code p1309
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=10
this site says it is misfire monitor problem
i have already replaced cmp per code p0340
thanks
confused
Old Jan 15, 2003 | 11:27 AM
Racerguy's Avatar
Racerguy
code p1309
This is right out of the Ford shop manual........
HD40 CHECK CMP SENSOR OUTPUT
Diagnostic Trouble Code (DTC) P1309 indicates Misfire Detection Monitor is not enabled.
Breakout box installed, PCM disconnected.
Connect digital multimeter between PCM test pin 85 and test pins 51 or 103.
Bump engine in short burst with the starter without starting engine for at least 10 engine revolutions.
Does digital multimeter reading switch between low (less than 2.0 volts DC) and high (greater than 8.0 volts DC)?
Yes
Note: A Hall effect type CMP sensor that is installed out of synchronization will produce a DTC. VERIFY the correct installation by referring to the Powertrain/Engine Group in the Workshop Manual. If the CMP is installed properly, REPLACE PCM. RESTORE vehicle. RERUN Quick Test .
No
REPLACE CMP sensor. RESTORE vehicle. COMPLETE Misfire Monitor Repair Verification Drive Cycle. RERUN Quick Test .
Old Jan 16, 2003 | 03:04 PM
cecil's Avatar
cecil
code p1309
thank you very much!!!!!!!!!!
Old Jan 16, 2003 | 06:59 PM
jaystersj's Avatar
jaystersj
code p1309
crazy96863
Nov 30, 2014 10:54 PM
dwollum
1983 - 2012 Ranger & B-Series
Apr 13, 2014 12:46 PM
almus
Jun 9, 2007 01:49 PM
Xdrive
Feb 10, 2007 05:58 PM
l965mustang
1997 - 2003 F150
13
Mar 5, 2005 11:03 AM
