Picnic Tables
Old Jun 10, 2004 | 11:54 PM
Mil1ion's Avatar
Mil1ion
Picnic Tables
I have scoured the net & books,magazines looking for plans for a special designed picnic table.
My Dad built one like this back in the 60's.
The thing that's different is the 2x6 construction, but more importantly the seating tilts up a few degrees when not in use so water/rain/moisture won't lay on it.
Has anyone seen a Picnic table built this way & know where I can get plans?
Old Jun 11, 2004 | 03:26 AM
peppy's Avatar
peppy
One day.....when I needed some psycho therapy away from everyone.....
I built a picnic table. All 2x6 except the seats, 2x8's. I made it from a picture in my head. I just started cutting 2x6's. Seats 10 people easy. Even turned out to hold a dozen people sitting on the table top itself. Ninety linear feet of 2x6 just for the table top. Its kinda big.
I guess I could sit down and try to figure out plans for it. I'll give it a shot and let ya know how I do.
Old Jun 11, 2004 | 08:21 PM
Jerrybo66's Avatar
Jerrybo66
Picnic tables aren't that complicated you should be able to draw one yourself. When I retired I started building picnic tables for beer money. I drew a sketch with all dementions and a material list. I was ready for production but decided it wasn't worth it. Mine had a 4X4 mortised frame though. The one I have now I made a formica top. If you store yours outside only paint the top and edges of the boards and it will last a lot longer. Wood needs to breath. I had one last 15 years until my son-in-law ran over it with a back-hoe. Yes, he's still alive...
Old Jun 11, 2004 | 09:01 PM
Mil1ion's Avatar
Mil1ion
I can build a regular table no problem.
I am just trying to figure out how to incorporate the slightly tilt up seating.
I realize they would have to be bolted for swivel, but it's the intricate seating part I'm having trouble with ,while trying to keep the weight of the whole table down.
Old Jun 11, 2004 | 09:33 PM
peppy's Avatar
peppy
I sit here and stare at a computer screen for a living.......in my frequent boredom I will try to come up with a dozen bad ways to swivel those seats.
Due to my nature...I must also ask if a little Thomspons Water Seal would do the same trick.
I already have a few bad ideas. I've make em impossible by the nights end.
Old Jun 11, 2004 | 10:02 PM
weadjust's Avatar
weadjust
Here is a picture of one.
http://www.lowes.com/lkn?action=prod...9-18866-PT6-KD
You can buy one at lowes for $74.00. Lumber to make one probably would be close to that.
Old Jun 11, 2004 | 10:41 PM
Mil1ion's Avatar
Mil1ion
After entering a zip (90210) it's the only one I remember
I tried 3 times.
It says it isn't available anymore.
Old Jun 11, 2004 | 10:44 PM
weadjust's Avatar
weadjust
Try my zip code 38801.
Link works for me and they had a bunch of them in front of the store when I was there the other day.
Old Jun 11, 2004 | 10:59 PM
Mil1ion's Avatar
Mil1ion
Thanks, That worked.
The only table I saw was a standard table, it didn't have the tilt-up seating.
Old Jun 12, 2004 | 03:17 AM
Mike W's Avatar
Mike W
Talking
Who has time for a picnic? A piece of plywood on sawhorses would probably work and you could take it apart.
Old Jun 12, 2004 | 10:56 AM
Mil1ion's Avatar
Mil1ion
That would be like you running beside a 265/R80/16 tire hitting it with stick to keep it rolling instead of actually driving your truck
Old Jun 12, 2004 | 01:29 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Assuming it's the usual design (found in parks, etc), couldn't you do a little extra work on the horizontal members that the seat mounts to such that the seat would be hinged? Also, since a few degrees of slope is all you're looking for, perhaps the horizontal boards that support the seat could be cut to give you a little slope on the seat (fixed mount). The slope would be so slight that nobody would notice it yet rain would run off.
Old Jun 12, 2004 | 01:37 PM
Little Bro's Avatar
Little Bro
There is available a set of pair of picnic table supports (you supply the lumber) which results in half a picnic table in which the table top swivels, thus forming either a bench (almost vertical) or a half-table (horizontal). Two sets obviously makes a full table. The supports are made of a dense, strong, green plastic. Very sturdy. If you'd like a picture, I'll post one. No longer have the name or literature, but think I've seen them in the big box hardware stores.
Old Jun 12, 2004 | 09:53 PM
F2504x4's Avatar
F2504x4
dennis,
the support boards that you mount the seating boards onto, where those are bolted ,you cut 2 slots approx. 3" long , on the other end of the board you would cut a 45 degree slot. you do this on all 4 mounting points of the support boards, that way when you pull out on the seats it will slide out and upwards.
__________________________________________________ _______________
_
\ \ <---this represents the 45 {direction of slide <----}
\ \_________ ............................. ______________
-\----X-----l . .......................... l_____<-_X_->_____l
the x's represent the bolts in the slots......crude drawing but maybe you get the idea. these are the slots cut into the support boards
if you use flat washer's and double nut the bolt it will slide out and up
wezol5484
40
Mar 23, 2011 12:02 PM
88Vmax
Feb 21, 2008 07:04 AM
boulderdentist
24
Feb 26, 2007 01:20 PM
BuiltToughF250
21
Apr 13, 2006 10:16 PM
gypsyrose31299
13
Sep 5, 2003 08:40 PM
