460 serpintine pullies
Old Jun 10, 2004 | 10:58 PM
88mgt's Avatar
88mgt
I have a 71 f-250 4x4. I am instaling a 460 and was wondering about puting a serpintine belt system on it. im having trouble finding anything and would apreciate any help
Old Jun 11, 2004 | 06:09 AM
Tiremine's Avatar
Tiremine
March has everything you need. Only problem is you better be sitting down when you look at thier price list.
http://www.marchperf.com
Tiremine
Old Jun 11, 2004 | 06:33 AM
Breeze's Avatar
Breeze
Price = Salty!!! Cust. service = good, Tech guy = Excellent!!! I just used a set on a 429 conversion I am doing, the fit and finish were excellent, all the brackets, bolts, spacers, etc are there in the kit. I ordered a A/C compressor from them and the OL accidently ordered the wrong one, since I was in the area I stopped by their facility and they swapped it right out, and the tech guy came over answered some questions and even went upstairs to get the dummy block with all the brackets in place so I could see where the idler and all was set-up at as the idler pulley (on A/C kits) wasnt shown real well in the diagram. You will need to change the PS pump over to a saginaw style pump (I used one spec'd for a 75 Camaro with the press fit pulley to match the kit) The only other issue I had was the AC mounted over the PS where it was difficult to check the PS level. I hooked the AC support bracket up differently than they had in the diagram (I used the boss on the lower radiator hose spigot) and used a slightly longer belt, and wa-la!! AC is on, PS can be checked, and it does look good!! Only other issue I noticed was that the bolt for the alternator to the head that comes in the kit is a 3/8 bolt, if your heads use the 7/16 bolt, you will need to get a longer bolt and drill out the bracket and spacer to accomodate the larger bolt. Took me all of 5 mins to do it
Old Jun 11, 2004 | 07:51 AM
Tiremine's Avatar
Tiremine
Breeze,
I checked out your pics. Those aluminum heads are sweeeet!!! Do you have any shots of the pulley setup. I'd love to see them.
Tiremine
Old Jun 11, 2004 | 11:03 PM
Breeze's Avatar
Breeze
Talking
Thanks!! I'm loading the album tonite, should be a couple there, if not, I will add some in the am!
Old Jun 24, 2004 | 04:30 PM
88mgt's Avatar
88mgt
thanks for the reply, that was the only ones i found also and the prices are steep. did you have to use an electric fuel pump with those.
