alignment or shocks?
Old Jun 10, 2004 | 08:39 PM
scooterman320's Avatar
scooterman320
I have a 99 xlt. Lately I've been getting a noise from the front tires indicating uneven wear. The best way to describe it is when you look at the tread of the tires you'll notice that part of the tire is dirty and a part of it isn't. In the past I understood this to be an alignment problem, however today I was told this is a shock absorber problem. Has anyone had any experience with this? Any suggestions would be appreciated. Thank you.
Old Jun 10, 2004 | 08:44 PM
golfboy17's Avatar
golfboy17
Ok sounds to be an alignment problem, does the car pull at all? you can also test the shocks by pushing down on the front end of the explorer if it bounces up and down more than a few times shocks are shot, if you replace them you should get an alignment as well.
Old Jun 10, 2004 | 08:54 PM
scooterman320
No, it doesn't pull at all. I will try pushing down on the front end next time I am with the explorer.
