Yet another Wheel/tire question
Old Sep 29, 2014 | 02:44 PM
cw_mi's Avatar
cw_mi
Next month I will be purchasing new tires for my Ex., not usually a big deal. I already know what brand and model tire I want and I'm on the fence on if I'll purchase new wheels as well, since the factory ones have the clear coat peeling off of them. If I do a wheel / tire combo should I stay with the 16" inch wheels and the 265 tires ? Are there benifits to going to a 17 or 18" wheel ? At the moment the truck sits at the factory height and I mostly just use it on our trips up north... so no offroad duty or anything. I tow a #7000 trailer on occasion so I'm not sure if I want to go with too much taller of a tire with the 3.73 gears (V10).
If the funds are good at the time of purchase I will most likely go with new wheels along with the tires, purely for the cosmetic part of it so it would be perfect for a wheel size change.
Suggestions ?
Old Sep 29, 2014 | 02:47 PM
Apocalypse's Avatar
Apocalypse
Is there a specific look you prefer? Do you like the OEM look? Do you love chrome like no other? Is flat black not as dark as your soul? You planning on running more for looks or for MPG? Lots of info to really get a good answer
Old Sep 29, 2014 | 09:25 PM
cw_mi's Avatar
cw_mi
Mileage?? You are kidding right? Its a V10 Excursion...LOL. I don't want it to get any worse though. I do like the square openings on the later model OEM wheels,don't really know year they would be though. My 01 wheels have oval type openings. Chrome does nothing for me, and my truck is bone stock (blue/brown) so black wheels as cool as they are won't look good on my rig. I guess I'm pretty boring...the OEM-ish look will be fine. Whatever I do I don't want to sacrifice ride or handling,or lose any kind of towing power by going with too tall of tire.
Old Sep 29, 2014 | 11:37 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Now would be a great time to step up to an 18" rim with a 285/60 or /65 tire. They come out to damn near the same size as a stock tire, still with decent sidewall. You'll get a slightly stiffer tire which should help with the handling a little bit, plus since so many manufacturers are doing 18" and up rims, they're actually a bit cheaper than the 16's in the same overall size.
Old Sep 30, 2014 | 08:26 AM
cw_mi's Avatar
cw_mi
Thanks Matt, this is what I'm looking for. The 18" is going to require a spacer correct ?
Old Sep 30, 2014 | 09:33 AM
Apocalypse's Avatar
Apocalypse
If you go with the 04- then no, but the 05+ yes.
Old Sep 30, 2014 | 09:43 AM
cw_mi's Avatar
cw_mi
Thanks, also PM sent
Old Sep 30, 2014 | 03:53 PM
Apocalypse's Avatar
Apocalypse
Old Sep 30, 2014 | 04:09 PM
cw_mi's Avatar
cw_mi
Thanks for posting the pics up Apoc, now I'm really set on the 18" wheel /tire combo. Your truck looks good with that combination.
Old Sep 30, 2014 | 07:16 PM
holeshotwalt's Avatar
holeshotwalt
His 2wd looks cute sitting so low, too! Almost looks lowered, even. WTF Apoc?
Seriously, though cw mi, I went with 20" rims with 33" tires to help eliminate some of the sidewall flex of the stock 16s. Helped a lot!
Then, put a OEM 30mm rear sway bar on, and had another (bigger) cornering improvement. I would definitely go with at least 18s if you can!
Old Oct 1, 2014 | 09:39 AM
Apocalypse's Avatar
Apocalypse
At least when I... I got nothing....
WAIT!!! When I hit the throttle and that 5.4 screams..... yeah, I got nothing...
Old Oct 1, 2014 | 11:21 AM
Krazee Matt
Veteran: Navy
At least when I... I got nothing.... WAIT!!! When I hit the throttle and that 5.4 screams (in agony)..... yeah, I got nothing...
Fixed it for ya
Old Oct 1, 2014 | 11:51 AM
Apocalypse's Avatar
Apocalypse
Fixed it for ya
When I hit the throttle and that 5.4 screams (in GLORY WITH AMERICAN FLAGS WAVING IN THE BACKGROUND AND EAGLES FLYING FROM THE EXHAUST TOWARDS FREEDOM)!!!
Fixed it again
Old Oct 1, 2014 | 12:02 PM
holeshotwalt
That'll be just about enough coffee for you today, Apoc....
Old Oct 1, 2014 | 04:25 PM
jamesbfishin's Avatar
jamesbfishin
I dunno, I think his 2wd EX is cute, and look at it this way, even in 2wd trim it still has a more ground clearance and an aggressive look than any stock GM 4x4 suv
Drive with pride my friend
