water in fuel
Old Jun 10, 2004 | 03:55 PM
txracer's Avatar
txracer
water in fuel
my water in fuel light comes on constantly. will go a day or two sometimes after i drain it, then come back on.
all i do is turn the switch(lever) under engine cover to drain the water. when it stops i turn the lever back. Should i be doing something else to get all the water out? I know fuel filter needs to be changed, will this affect it?
Thanks For Any Input...........1997 7.3 with 114,000
Old Jun 10, 2004 | 05:23 PM
Fire Rooster's Avatar
Fire Rooster
That is all you do but it sounds as if you got a bad batch of fuel. You either need to run it out or drain the tank fill it up with good fuel and change the filter. Run some diesel kleen in it too, as this will help keep the water separated and in the fuel bowl.
Fire Rooster
