oil drip at plug
Old Sep 7, 1999 | 05:49 PM
steve mason
Guest
Posts: n/a
oil drip at plug
Can anyone tell me how to stop this oil drip around the plug. I put a new copper washer that did not work. Any suggestions are greately appreciated!! I have a 99F350 PS. Also when can I use the Ford additive to the radiator cooler and how much? Again many thanks.
Old Sep 8, 1999 | 08:21 AM
Phillip Guidry's Avatar
Phillip Guidry
oil drip at plug
Have you seen the washers with the o-ring built into the center hole?I'm suprised that it's not original on your engine.Check the dealer again or look for them at a parts store.If available,you may have to order for your diameter.Sorry, can't help you on the additive for the radiator.
Phillip
Old Sep 8, 1999 | 04:10 PM
A. C. Douglas
Guest
Posts: n/a
oil drip at plug
>Phillip
The owners manual says to add FW-15 every 15000 miles, or you can check it with the Fleetguard strips to make sure it is at the proper level.
Old Sep 9, 1999 | 05:20 PM
woodwalker's Avatar
woodwalker
oil drip at plug
Old Oct 3, 2007 | 01:39 PM
Dukernc's Avatar
Dukernc
I had the same problem with my PSD and picked up the copper washer with the o-ring built into the center hole at NAPA. Worked great! I also had the same problem with the drain plug on my F150. I put a new plug & plastic washer during the last oil change and I still had the problem. Not as bad as previously but, it was still there. I couldn't find a replacement copper washer at the time. So, I ended up draining the oil into a clean pan. I then applied some pliable permatex to the plug and washer and the problem was temporarily solved. I've since picked up a hand full of the copper washers with the o-ring built in for future oil changes. Good Luck.
Old Oct 3, 2007 | 04:39 PM
Robert6401's Avatar
Robert6401
Do a search on the Fumoto Oil Drain Valve. I had a leak that no plug or washer combination seemed to want to fix. I sprung for the Fumoto and not only did it stop the leak but changing the oil is much cleaner. Good luck.
Bob
Old Oct 3, 2007 | 05:15 PM
PSNut's Avatar
PSNut
Here's one: http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=33
Everyone loves this gadget.
Old Oct 3, 2007 | 08:12 PM
yellow401's Avatar
yellow401
HA! I fought the same damn problem using copper washers with no luck! Drove me crazy cuz I can't stand wet/damp/leaking anything. Finally found that pep boys has a synthetic washer for the drain plug, same size, and it seals perfectly. It is like a stiff yet flexible, well, synthetic material. Was green in color. Try them I guarantee they will work!
Old Oct 3, 2007 | 10:28 PM
jtharvey's Avatar
jtharvey
I wonder what's causing some copper washers to leak and others are ok. I've been using new copper washers at every change for the last 4 years and have not had one leak yet.
Old Oct 4, 2007 | 12:59 AM
twags6's Avatar
twags6
Its funny cause I have yet to change the washer on mine, and thats with two years worth of oil changes. No leaks yet.
Old Oct 4, 2007 | 07:17 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
It took me 2 years to buy a Fumoto valve and now that I have one I want to get one for all my other vehicles. I never changed the copper washer (10 oil changes) on my truck untill I got the fumoto and never had a leak. On my sons Explorer if I dont replace the washer every oil change it will leak. Explain that one to me!!!
Old Oct 4, 2007 | 07:21 AM
Izzy351's Avatar
Izzy351
This is like the 4th or 5th time that someone brought something up that I've been experiencing as well. I haven't been getting the new washers with my OCs, but I will now. I've got quarter-sized spots in the garage when I leave in the morning and it's coming from the plug. Go figure...
Thanks for the tips on the O-ring washer -- I was just going to get the copper one this time.
Joe
