Sponsored by: Auxito
2001 E 150 van--starts, won't run
Old Jun 10, 2004 | 03:42 AM
tarheeldad's Avatar
tarheeldad
Love our van. Having a problem for the second time and no one seems to have an answer. The engine will start (battery cranks, adequate battery charge)- but the engine will die unless I keep depressing the gas. When I shift into gear the engine dies.
Local mechanics at two different dealerships have no idea what's wrong. Because after I tow the vehicle in it will start.
Any suggestions?
Old Jun 10, 2004 | 07:46 AM
matr8er's Avatar
matr8er
IAC maybe?
have you tried an idle air control yet?
Old Jun 10, 2004 | 08:05 AM
PaulC's Avatar
PaulC
Seems like the IAC valve, as suggested above. Do a site search on IAC replacement.
Old Jun 10, 2004 | 10:53 AM
myke's Avatar
myke
I agree on the IAC. Had the same problem on my van. I read what seems like a thousand posts on this site of other people with the same thing. Do a search - there are instructions here about how to remove & clean it.
Old Jun 10, 2004 | 04:42 PM
tarheeldad's Avatar
tarheeldad
Thumbs up 2001 E150 van
Tahnks for your help! You gave me confidence in dealing wit hthe dealerships mechanics. OIf course, you were 100% correct.
Question, though: the new control valve cost $131 and the labor was $146 (2 hours).
(1) Seems like a lot of time to run the diagnostic and pul and replace the valve. Is it a lot of time---2 hours?
(2) How come the valve's can't just be cleaned? Its a small part that plugs in. No doubt it was sticking because it was dirty. But I saw no screww holes on the part to enable opening it up.Curious about any feedback on this.
Thnaks to all!!
Old Jun 10, 2004 | 08:28 PM
Racerguy's Avatar
Racerguy
I'm in Canada so I cant really comment on the price of the part.
The labor is possibly a bit high but not unrealistic.
A lot of shops have a minimum 1 hour charge for any EEC work.
If they pinpoint tested and monitored live data it could take longer.
To get at the IAC on a van the inside engine cover has to be removed so that takes a bit longer. The valve itself doesn't take long to replace. It has 1 connector and 2 screws.
It wouldn't hurt to ask them for a breakdown of the labor charge though.
The valves can be cleaned but usually it is only a temporary repair and the shop doing it doesn't want to have you come back with the same problem in a month.
Old Jun 10, 2004 | 10:47 PM
PaulC's Avatar
PaulC
Consider the IAC to be a part that requires replacement about every 50,000 miles.
I know, I know, someone on the board has an E-150 wth 760,000 miles that hasn't even needed an oil change yet...
does home renovation
General Automotive Discussion
Feb 7, 2013 06:03 AM
bburrito
Aug 18, 2010 07:42 PM
1ford1
32
Feb 13, 2008 08:53 PM
drive_old_ride_new
Dec 17, 2007 09:50 PM
bozomedic
Aerostar
Dec 27, 2005 04:45 PM
