Transmission problem C6
Old Jun 9, 2004 | 10:11 PM
Fordbychance's Avatar
Fordbychance
Question Transmission problem C6
My transmission seem like it doesnt shift right.It revs real high when i take off before it shifts into passing gear.What would cause this? Modulator?
Old Jun 10, 2004 | 07:01 AM
RichardMaerz69's Avatar
RichardMaerz69
I don't whant to give you any bad info here,so if I'm wrong sombody jump in.If you have never changed the filter and oil in the tranny that could be your problem,it could also be your modulator.How old is the tranny and what is it in,it could be just an adjustment to the linkage set up.But it should shift from vacume alone,I'm starting to have the same problem with mine in my 81 f150 351m c6 just hanen't lookeds at it yet.
Old Jun 10, 2004 | 07:35 AM
nzabka's Avatar
nzabka
Richard is right, I'd begin with changing the tranny filter and fluid. Make sure you drain the torque converter too, it holds quite a bit of fluid. And yes, while your at it, stick a modulator on it too, they're pretty in-expensive. I bet the new filter and fluid fixes your problem.
Old Jun 10, 2004 | 08:39 AM
dmuncy's Avatar
dmuncy
Thumbs up
I would flush the system while you are at it.You can buy trans flush at auto parts stores.
Old Jun 10, 2004 | 09:16 AM
dennhop's Avatar
dennhop
My buddies C6 did that after we broke his tranny cooler. We just had to route the lines back to the tranny, so it cycled back through itself. Because the coolant wasn't getting cooled off sufficiently, it overrevved. Once we put a tranny cooler back on, the tranny shifted fine.
Old Jun 10, 2004 | 09:52 AM
fai4g63's Avatar
fai4g63
Sounds like your modulator-cheap and easy fix.
Old Jun 10, 2004 | 10:05 AM
Fordbychance
Arrow C6 transmission
Mine is an 86 Ford F-150 4x4 C6 .I just recently purchased the truck so it probly needs a fluid change.But i will look at all avenues to figure this out i guess.
Old Jun 10, 2004 | 11:46 AM
fellro86's Avatar
fellro86
Most certainly try all aforementioned ideas, and if no succes, i unfortunately would have to say that your direct clutch is just about finished, the flare being slip, however, it can simply be a hanging shift valve, and sometimes shift kits can be the answer, Look for excessive sediment in the pan, lots of black deposits, and brass flakes. Some is normal, but a lot is not. If there is a straight line of deposits, rebuild is necessary, as that clutch pack is gone. I had one in a 75 250 that was always like that, and never failed, but was likely a shift valve problem.
Old Jun 10, 2004 | 01:19 PM
Nightrain's Avatar
Nightrain
Yes, begin with the fluid and filter change, and drain the converter also. 95% of the time, this is what's wrong with automatics. The modulator could do the trick also.
Good luck.
Nightrain
paker
1997 - 2003 F150
17
Oct 1, 2011 07:59 PM
gfanucci
Sep 11, 2001 01:53 PM
FTE Ken
Escape & Escape Hybrid
May 31, 2001 12:16 AM
doc33
Apr 18, 2001 06:52 PM
