Trouble code P0402
Old Jun 9, 2004 | 08:31 PM
tomf52's Avatar
tomf52
Question Trouble code P0402
Check eng light on, book says excessive exhaust gas recirculation flow detected. 1998 2.5 4cyl . Any ideas what may be the cause besides maybe a stuck open egr valve (which is only 10,000 miles old)? Thanks for any help.
Old Jun 11, 2004 | 04:04 PM
BassGuy's Avatar
BassGuy
Go with the EGR sensor first (also called the DPFE or Differential Pressure Feedback EGR sensor), since it's cheaper and much MUCH easier to replace.
Make sure you also check your vacuum lines for leaks or loose connections.
Old Jun 11, 2004 | 08:59 PM
Ken00's Avatar
Ken00
I'm leaning toward the valve problem.
Old Jun 13, 2004 | 09:34 PM
Coot's Avatar
Coot
Exclamation
How about PO405 code I have it on my 2002 F150 Supercrew. I got the code read at Autozone it read Exhaust recirculation sensor A low. Would a new DPFE sensor also be the culprit in this instance.
Thx,
Coot
brandonorban
18
Mar 1, 2012 08:55 PM
savage_racing
May 17, 2008 02:10 PM
Placermike
N. California Chapter
56
Mar 6, 2008 02:04 PM
cbfomoco
Oct 22, 2005 07:58 AM
jaymoford
Mar 19, 2005 11:11 PM
