How hot do the front brake rotors get? After driving around town with usual red lights, etc., I parked the expy and spit (very scientific test) on the rotors. It boiled the water off. Is this normal? I jacked the right front up and rotated the tire by hand. I could rotate it with little pressure, but it would stop as soon as I removed the pressure.
If your doing the 'spit' test after one or two blocks, that's excessive heat.
Any longer duration than that and your test is getting the typical rotor heat build up.
Unless brakes are seizing up on you or pulling, doesn't sound like any problem.
