HELP! Tranny/Speedo Problems.....
Old Jun 9, 2004 | 08:02 PM
JW 4x4's Avatar
JW 4x4
Truck in question is '95 Ford F-350, 4x4, 351W, E4OD, 133" wheelbase.
Had to jack transmission up about 3 inches to replace transmission mount as it was broken, after replacing trans. mount, shifts hard into second and third, Overdrive Off light flashes repeatedly, and speedometer/odo do not work. I assume it is something electrical, what should I check for? Thanks.
Old Jun 9, 2004 | 08:55 PM
fai4g63's Avatar
fai4g63
Check to make sure you did not knock any wires loose that plug into the transmission.
Also check your speed sensor connections.
