Sponsored by: Innova
please help no sound
Old Jun 8, 2004 | 10:48 PM
parnold80's Avatar
parnold80
please help me i have no sound
I have a 2000 explorer and have a pioneer radio/cd player. i had the radio hooked up and the back speakers went out and wouldn't register on the radio as being there so i took the radio out and checked the wiring and reconected the lose wire and when i hooked it back up no sound will come out. I have had the radio since sept. one of my friends told to take it back that it might something wrong with the radio itself. so i exchanged it for the same, but i'm still having the same problem.
Old Jun 8, 2004 | 10:50 PM
acerockola77's Avatar
acerockola77
Do you have the factory amplifier?
Old Jun 8, 2004 | 10:51 PM
MustangGT221's Avatar
MustangGT221
Already in audio/visual..unable to merge
Old Jun 8, 2004 | 11:00 PM
parnold80's Avatar
parnold80
i do not have a factory amp.
Old Jun 8, 2004 | 11:10 PM
Mil1ion's Avatar
Mil1ion
Moved to audio forum
No Truck tech questions on the general conversation forum please.
Old Jun 9, 2004 | 08:38 PM
MemOrex's Avatar
MemOrex
Does the radio iself power up? if it dont check the fuse panel. Do the speakers work?. At worse, your radio could've shorted out and ruined the speakers.
Old Jun 9, 2004 | 10:09 PM
parnold80's Avatar
parnold80
the radio has a signal and will play cd's but there is no sound I am totally lost on what to do
Old Jun 9, 2004 | 10:32 PM
pcarter13's Avatar
pcarter13
me to
i have the same thing happen to me need help to . a guy fix it last year .but he's not around now ,need help
Old Jun 9, 2004 | 10:45 PM
parnold80's Avatar
parnold80
i talked to a girl at the auto store tonight she said she had a friend that has had 3 mustangs and she had to replace the speakers im going to see if that will solve my problem, but that will have to wait untill payday i was planning on replacing them anyway
Old Jun 10, 2004 | 12:26 AM
pcarter13's Avatar
pcarter13
not tried to be funny but i would wait .this guy did something,he when under the hood and came back and look under the radio, and bam it was on ,i am a *** for not looking at what he did ,but i will try and get with him friday and will let you no .i have a 97 EXP i had a amp hook.and my wife took it out last year, and the wires are still there and i put something on top of them ,sound went out
fuse are good now and before .
Old Jun 18, 2004 | 01:15 AM
pcarter13's Avatar
pcarter13
Dumb Dumb
Look Under Hood On The Left Side . And It's A Small Fuse Box Change The 15amp Fuse And You Are Good To Go , Try It !!!!!! Not The Big One ,but The Small One ,it's Two There !!!!! :-x22
Old Jun 20, 2004 | 01:01 AM
drewcoolness99's Avatar
drewcoolness99
i did somethng with mine and i think a couple wires got crossed and i blew out the internal amp. Luckily it was under warranty.
Old Jun 20, 2004 | 09:57 AM
christaylor's Avatar
christaylor
Blue wire powers the factory amp... Make sure it has power.
Chris
Old Jun 20, 2004 | 12:55 PM
iang's Avatar
iang
Post no sound
first thing to do when you have no sound is double check connections at every speaker... then make sure the speakers terminals and wires aren't touching any bare metal in the car. While you have the speakers out make sure there is no loose solder pieces or metal coming off the terminals and making contact with the speaker frame. if still no sound chances are you have a factory amp and it has finally given way to the aftermarket cd player. most ford explorers have factory amps that are hidden and you might not even know about. you can tell however by the plug that is behind the deck.
Old Jun 20, 2004 | 12:58 PM
iang's Avatar
iang
Talking
to follow up on that... if one speaker terminal makes contact with the vehicles ground it can cause all speakers to loose sound even when it appears the cd player is still working fine.
