unknown engine
Old Jun 8, 2004 | 01:13 PM
sightseer's Avatar
sightseer
unknown engine
I just got a 47 1/2 ton p/u, and the engine has been swapped for a small block ford V-8 (289-351w). The question is how do can I tell what engine it is or what year it was manufactured in, or is there a way to find out what type of car or truck it came out of. Thanks
Old Jun 10, 2004 | 12:30 AM
terryr's Avatar
terryr
Oil level was checked at the front on early 289 then changed to side. 302 intakes are narrower than 351. Is there a serial number?
Old Jun 10, 2004 | 02:59 AM
sightseer's Avatar
sightseer
Thanks that helps a lot. where is the serial # you refer at? (bock, head ,or intake)
This is my first ford engine, I have been working on gm and dodge engines for years. When I found this truck I fell in love with it and I think ford will be my new hobby but I have to start over at the beginning. the # on the intake is 080e-9425-a
Old Jun 16, 2004 | 08:26 PM
bobcatv8's Avatar
bobcatv8
I think the 080E- you see on the intake is really d8de, which if so would make the intake at least a 1978 from {most likely} a mid size car. Bear in mind the vagaries of Ford casting numbers. You may have to pull more parts and get more casting numbers to pin down what you have!
Old Jun 17, 2004 | 06:31 PM
Matts72's Avatar
Matts72
well that narrows it down to a 351W or 302. I think a W intake is 10.2" across, a 302 is narrower.
4x4countryboy
29
Mar 17, 2012 12:00 PM
Damonkr
Mar 25, 2010 09:04 AM
sjniii
1983 - 2012 Ranger & B-Series
15
Oct 24, 2009 10:01 PM
RED350
Feb 23, 2005 08:19 PM
1966blueford
Aug 28, 2001 08:21 AM
