General Automotive Discussion
Anyone else use the Fram Sure Drain?
Old Jun 7, 2004 | 02:03 PM
75Player's Avatar
75Player
Just put one on the wife's Sport Trac this weekend. Talk about an easy, mess free oil change. Just unscrew the cap, screw on the supplied hose, and drain it straight into the disposal jug. Granted, the oil drains slower than it would if you just pulled the drain plug, but if you've ever changed the oil in a 94-up Mustang, you know how much of a pain it is to keep moving the oil pan as the car drains. Best $12 I've ever spent on the vehicles. Gonna put one on my F150 this weekend. Wish I knew about this thing when I had my Mustang.
Old Jun 7, 2004 | 06:49 PM
87 XLT's Avatar
87 XLT
At the first oil change on every car that i've owned for the last 20 years i've installed one of these very handy gadgets www.fumotovalve.com. Might go with the sure drain next time. I've seen them at Walmart & they look pretty good.
Old Jun 7, 2004 | 07:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
I use one on my 03 Expy.
SSSSSSSSLLLLLLLLLLLLLOOOOOOOOOOOOOOOOOWWWWWWWWWWWW drain time!!!
But...it gives me the chance to do other things.
Draining the oil without creating a mess has never been a problem on my vehicles, it's changing the darn filter that makes the mess! I now use a plastic shoppin gbag as a "glove" to remove the filter. It traps all the oil inside it.
Old Jun 7, 2004 | 07:55 PM
ubermich's Avatar
ubermich
GENIUS! But now I feel stupid.
Old Jun 8, 2004 | 06:49 PM
Beast12's Avatar
Beast12
I have one on my 85 F150 and used it for the first time a couple weeks ago. Works great! Drain the oil right into an empty used oil jug. No mess at all. It does drain slow but gives me time to grease my front end and u-joints. But I gotta be careful I don't forget to put the oil back IN the truck!
-Matt
P.S. The one and ONLY thing on my truck that says FRAM!
Old Jun 8, 2004 | 08:02 PM
ATC_250SX's Avatar
ATC_250SX
boy i saw those, i was gonna buy one, but i can see myself going somewhere im not supposed to be and smashing it off or somthing, how durable are they?
Old Jun 8, 2004 | 08:32 PM
Beast12's Avatar
Beast12
Well, I guess it depends on how much you go off-roading. They only stick out from your oil pan about 1/2". Your regular drain plug probably sticks out around 1/4". I think if you knocked one off you are probably going to do damage to your oil pan as well anyway. They got a protective cap (dust cap) that is a nice addition as well (comes in the kit).
-Matt
Old Jun 8, 2004 | 09:35 PM
ATC_250SX's Avatar
ATC_250SX
Hm, i may invest in one, although im impatient sometimes, just trying to get the oil change over with. are they really all that slow?
Old Jun 8, 2004 | 10:08 PM
themoonshineboy's Avatar
themoonshineboy
Mine took 30 min to drain 5Qts of 10w 30 on a warm day, but you never have to fish out your drain plug again. Droping the plug in the pan is a family curse I have from many before me.
Old Jun 8, 2004 | 11:48 PM
13MWZ's Avatar
13MWZ
I had one of the Fumoto drains on my Powerstroke. I liked it. I did a lot of off roading and never knocked it off, but it was on 35" tires too so........
Anyways, I hate Fram stuff so even if they made one for the Powerstroke (the part number their book shows is wrong) I wouldnt have bought it. Fumoto seems stronger anyways.
Old Jun 9, 2004 | 06:10 AM
75Player's Avatar
75Player
Like beast said, if you manage to knock it off while off-roading, the drain plug is probably the least of your worries. You'll tear up the oil pan at the same time.
Old Jun 9, 2004 | 04:31 PM
nick88f150's Avatar
nick88f150
i thought about getting one as well, however, like monsta said, ive never had a problem with that, its the filter that makes the mess. never thought of the plastic bag tho, good call on that. also, if you always drop your drain plug in the pan, try using vice grips/pliers to take it off the pan, it wont get dropped.
Old Jun 9, 2004 | 07:47 PM
ATC_250SX's Avatar
ATC_250SX
well 30 minutes for 5 quarts, im gonna stick to the regular drain plug, i can have it done twice by that time.. but i guess its good for some people.
Old Jun 9, 2004 | 07:49 PM
Beast12's Avatar
Beast12
30 mins is a bit extreme (unless you want every SPEC out). Mine only too around 15 mins to drain.
-Matt
Old Jun 9, 2004 | 07:52 PM
ATC_250SX's Avatar
ATC_250SX
I also run 15w40, thats not thin like 5w30, so it would prob. take me even longer and i never usually drop the drain plug, so, i guess im not gonna waste moneys,
