Valve Adjustment, 302
Old Jun 6, 2004 | 09:23 PM
packrat56's Avatar
packrat56
When I finally figure out the piston issue from my last post, I am going to need to put this engine back together. I have ordered a book, but I doubt it will be here in time.
Could anyone go over the process of assembling and adjusting the valves/lifters? I remember there is a way to do it while its running, but I can’t remember the whole process.
Thanks very
Old Jun 7, 2004 | 12:33 AM
Putt's Avatar
Putt
302's do not have an adjustable valvetrain, unless you have changed rockers studs etc?
Old Jun 7, 2004 | 12:47 AM
packrat56's Avatar
packrat56
What is the procedure to put the thing together? Do I just put the pushrods in, place the rockers on and torque the bolts to specs?
Old Jun 7, 2004 | 09:15 AM
59Fguy's Avatar
59Fguy
from the Haynes Manual:
"on later engines with the positive-stop rocker arm studs, the piston must be set to the TDC postion...the the rocker arm nut must be screwed down fully and tightened to a torque wrench setting of 18-20 lb/ft. Push the rocker arm down so the valve lifter is in the fully collapsed position and check the clearance between the rocker arm and valve stem using feeler gauges."
valve clearance ranges:
302 minimum: 0.067" maximum: 0.167" so.... you have quite a range of preload that the lifters can and do handle.
hope this helps.
sean
Old Jun 7, 2004 | 10:10 AM
packrat56's Avatar
packrat56
valve adjust, 302
That does help, thanks.
Do I need to have each cylinder at TDC before I tighten the rocker arm bolts?
What is considered a later engine?
Old Jun 7, 2004 | 05:25 PM
P51D Mustang's Avatar
P51D Mustang
Hi Pack Rat,
After about 1978, all factory 302's and 351w's, with the exception of the 90's Cobra/Explorer 5.0's, use pedalstal mount rocker arms similar to the 351C and 400 motors. This type uses a sled fulcrum to control side to side movement. You just bolt these down and tourqe to specs (16 lb-ft IIRC)when using hydralic lifters. The hydralic lifter compensates for all valve lash adjustments. They don't need to be at TDC when bolted down, provided the lifter bleeds off, but you may want to go through the firing order, after they are bolted down, and make sure you can turn the push rods with your fingers, when the valves for that cylinder are at 0 lift, or that cylinder is at TDC. Most pre 78 302s used non adjustable rockers that bolted to studs with positive stop shoulders. Side to side movement was controled by rails on the sides of the rocker tip that fit over the valve stem top. I don't care for this design but thats what the had. With this type you just tourqe the nut, and once again the hydralic lifter compensates for the lash adjustment. With hydralic lifters you don't want any clearance between the rocker tip and the valve stem or it will chatter.
Old Jun 7, 2004 | 09:58 PM
packrat56's Avatar
packrat56
Thanks very much, my heads are 1970 I believe, so I just torque to specs and test for a free spinning pushrod when at 0 lift? How much piston damage will this engine allow? A washer was chewed up in 2 of the cylinders.
Old Jun 8, 2004 | 07:46 PM
ga302p's Avatar
ga302p
Make sure the lifters are fully pumped up, and that should get you close enough.
A washer chewed up in 2 cylinders? elaborate.
Old Jun 8, 2004 | 09:27 PM
packrat56's Avatar
packrat56
Are you saying to measure rocker free play when the lifters are fully pumped up????
For a detailed discussion about the piston issue check out this thread of mine:
https://www.ford-trucks.com/forums/s...d.php?t=247299
Old Jun 9, 2004 | 12:12 PM
59Fguy's Avatar
59Fguy
no, you check rocker free play with NO oil in the lifter. the rocker arm tip will be touching the valve stem, when a cylinder is at TDC push the rocker arm (push rod side) down as far as you can (compress the lifter) and refer to the measurements in my previous reply. more than likely you will have no problems, if these are all the same parts you removed before and it was a running engine AND you didn't have the machine shop go wild with milling the heads. assuming all that just bolt the things down like P51D said and go drive your truck!
sean
Old Jun 9, 2004 | 09:58 PM
ga302p's Avatar
ga302p
sean
No, you check the lifter in the manner we described with the lifter pumped up fully. You check with a feeler gague with the lifter fully bled down. Big difference. Set one up where the push rod barely turns with the lifter bled down, and it will skip. We are discussing the "shade tree" method of adjusting clearance, not the service manual way. It is a strange thing that I do not know of the first mechanic that checks clearance with lifters bled. Even the mechanic at my local Ford dealership checks it the "shade tree" way. They dont even have a lifter bleed down tool in the dealership.
Old Jun 10, 2004 | 12:43 AM
packrat56's Avatar
packrat56
Ok, so I hate to open up another can of worms.. But here goes.
Background info:
I have a 302 with no noticable ridge in the cylinder, I am having the heads done due to my stupidity of dropping a washer in the intake and running it for a few seconds.(Machine shop said the guides are indeed bad so Im going ahead with guides and valves)
Question, Should I replace the lifters as a routine thing as long as the heads are off, or leave them alone (they sounded just fine before) ?????? Are lifters expensive? Im totally broke already, by the way..
The washer in the cylinder story: https://www.ford-trucks.com/forums/s...d.php?t=247299
Thanks everyone..
Old Jun 10, 2004 | 09:06 AM
59Fguy's Avatar
59Fguy
ga302p,
you must not know any mechanics that do machine work. i have been down this road with a couple of ford engines that were milled for comprssion and squelch area, thus leading to the requirement of different length pushrods. you find this out by doing what i posted. don't and you can and will break valve train components. same thing applied to the mopars i have built. frankly, i'll keep doing it "by the book" as it has done just fine by me.
packrat,
after reading your other post, it seems to me you have a fairly low mileage engine. go ahead and put that dude together, especially considering the financial aspect as stated in your previous post. i realize i have not seen your engine, but i think you will be ok.
sean
Old Jun 10, 2004 | 09:14 AM
packrat56's Avatar
packrat56
Thanks sean. Thanks everyone for the info, I am learning a lot here, it is appreciated!
Old Jun 10, 2004 | 03:46 PM
ga302p's Avatar
ga302p
ga302p,
packrat,
sean
Not only do I know mechanics that do machine work, I do machine work. I also build race engines and street engines. I was describing the way you roughly check pushrod length. If you have an engine that the pushrod will barely spin with the lifters bled, It does not have enough clearance and will skip. With the lifters bled, you check with feeler gague. He wasnt asking about checking with a feeler gague, he was asking about checking by spinning pushrods. I change every Ford small block I build over to Chevrolet, adjustable, stud mount rockers. I have to adjust every one of the rockers. I can promise you if the pushrod will barely spin with the lifter bled, the engine will skip at rpm.
