Tachometer Hook-up
Old Jun 6, 2004 | 08:26 PM
Dustin_86's Avatar
Dustin_86
Tachometer Hook-up
I hook it up accoring to the instructions and a test light for the fuse panel- hot when key is ON only-power- cool thier right..well 1 day later uuurrr.. uuuuuurrrrrrrrrrrr............. click click.What the #$#% so I unhooked it and it was fine for a week then I thought well I hooking it back up-I just unhooked the power to the fuse pAnelI hooked that back up and 2 days later.........uuuuuurrrrrr ........uuuuuuuuurrrrrrrrrrrrrrrrrr..... click click
PLEASE HELP,
thanks,
dustin
Old Jun 6, 2004 | 08:42 PM
Franklin2's Avatar
Franklin2
Verify what's going again with the test light. Leave the tach hooked up. With the key off, check for power. I don't know if you have a seperate ground wire, or you have the tach mounted to metal, or you may have added a ground wire to the tach. Whatever the case, make sure when you test for power, you test where the tach is hooked as far as power AND ground. Test exactly what the tach sees where it's hooked up.
P.S. Also remember you probably have an extra wire for the illumination of the tach(light bulb inside for the dial). Make sure this is not a problem.
Old Jun 6, 2004 | 09:55 PM
Dustin_86's Avatar
Dustin_86
It has a factory ground wire I checked withj a test light and thier is a DIM and I mean DIM light from the test light. Maybe a short in the tach?
Old Jun 7, 2004 | 01:02 PM
Franklin2's Avatar
Franklin2
If the tach had a problem, it could only cause a problem when the keyswitch was on. If it was properly hooked up to a circuit that was connected to the keyswitch, then the circuit will be completely dead when the keyswitch was off. Apparently you do not have it hooked to the right spot in the fuse box. Try somewhere else. The radio circuit should work.
