E4OD Electric Shift Module
Old Jun 6, 2004 | 05:54 PM
ALSAIR's Avatar
ALSAIR
Hey Guy's. I got a 1994 F-150. It has a E4OD tranny that was re-built in 2000. It shift's fine when cold, and after that it slips and slams into gear. I changed the tranny fluid when I got it 5,000 miles ago and she still looks like fresh fluid, no darkening or nothing. What is the module called that controls the shift points and where is it located. I am going to start there and see where it takes me.
Thanks Al
Old Jun 7, 2004 | 10:38 AM
jimandmandy's Avatar
jimandmandy
The Powertrain Control Module is an integrated computer that controls both your engine and transmission. There is not a separate one for the trans. The diagnostic connector is under the hood on the drivers side. You need to dump the codes to see if the PCM knows what is wrong.
Jim
FN250super cab
New Member Introductions
May 10, 2025 04:37 PM
Beau109
Aug 16, 2015 12:10 PM
Mowing Man
Apr 5, 2014 05:59 AM
therigwelder
Nov 27, 2013 01:41 PM
big ole ford
Aug 27, 2012 02:29 PM
