P Code 1401
Old Jun 6, 2004 | 05:27 PM
justbrit001's Avatar
justbrit001
P Code 1401
I have a 98 Ford Ranger 4 cyclinder and the check engine light is on. I went to autozone and had it scanned. Came back with P Code 1401 DPFE EGRCircuit High Input. I have already changed the EGR valve and the DPFE Sensor. All the vacuum lines appear to be okay. At this point I am out of ideas....anyone else ever have this problem or know of anything else I can check.
Old Jun 6, 2004 | 08:00 PM
Dealford's Avatar
Dealford
Welcome to FTE.
I pulled this from the "Technical Information" sticky:
http://rockledge.home.comcast.net/Ra...llery/DTCs.pdf
There is more info on the EGR subject there too.
AL.
Old Jun 7, 2004 | 07:11 AM
justbrit001
Maybe its a wiring problem????
Thanks DealFord,
Considering I have already changed the sensor and based on the info. that you sent. Do you think it would be safe to say I have a wiring problem????...I suppose I could stick it on a meter this evening and find out. Thanks again.
