Adjusting doors
Old Jun 6, 2004 | 05:00 PM
JEEPULLR's Avatar
JEEPULLR
Adjusting doors
83 F250
Passenger door rattles. When sitting still it lines up with the body, (sits flush) but I can push it in by 1/4-3/8 inch and pull it out beyond the body about the same. Can't see a way of adjusting the pin in the frame, or any way of moving the latch around...
What's the trick?
Old Jun 6, 2004 | 05:20 PM
fai4g63's Avatar
fai4g63
Check your striker bolt, it should have a plastic cover on it to keep the door from ratteling.
Old Jun 6, 2004 | 06:52 PM
prcrboy's Avatar
prcrboy
exactly, the plastic can wear and allow play. To adjust the pin, you can loosen with a torx wrench. If it has play both ways, that adjustment won't help much
Old Jun 6, 2004 | 07:23 PM
Technonut's Avatar
Technonut
A new striker bolt can be had at Advance Auto Parts for around $8.00. Sounds like the plastic sleeve is worn on yours....
Old Jun 6, 2004 | 07:57 PM
JEEPULLR's Avatar
JEEPULLR
The plastic striker would be it...no plastic here. Thanks for the info.
Old Jun 7, 2004 | 12:24 AM
bigbrown84truck's Avatar
bigbrown84truck
if there is no plastic that is the problem, i had the plastic cover break completly off of my bolt, making it all metal and it rattled like an SOB, i thought the door was gonna fall off when i'd hit a bump too hard at 65. anyhow, got to Napa and get a new door striker post bolt.
Old Jun 7, 2004 | 04:12 AM
srercrcr's Avatar
srercrcr
If you want to take the cheap route, cut a piece of 1/2" PVC to length, slice it, slip it over, works good, just a tad of play.
Old Jun 7, 2004 | 09:04 AM
Nightrain's Avatar
Nightrain
I've got the same problem.I thought that it was due to worn door hinges,but I guess that it's alot simpler than that .Gotta get me some of those door strikers sometime soon...
Now if I could just get that fender and hood aligned ...
Nightrain
Old Jun 7, 2004 | 10:27 AM
JEEPULLR's Avatar
JEEPULLR
But that would make it too pretty...
Old Jun 23, 2004 | 03:32 AM
Spktyr's Avatar
Spktyr
I've got the same problem. That Torx looks pretty big, anyone know what size it's supposed to be? I don't have a Torx bit that large...
Old Jun 23, 2004 | 09:04 AM
82F100SWB's Avatar
82F100SWB
Vise grips work just fine if you don't have the proper torx. The striker isn't all that tight.
Old Jun 23, 2004 | 03:13 PM
bigbrown84truck
the striker is a t-50
Old Jun 28, 2004 | 10:45 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Adjusting the striker is definately the easiest route to stopping the rattles, but changing those worn out door seals really stops the rattles and the wind! Whitney has the door seals (weather stripping) and they are fairly cheap ~$30 ea. I changed mine and I'm glad I did it. even restored my door alignment
Old Jun 28, 2004 | 10:48 PM
Spktyr's Avatar
Spktyr
Wouldn't help on mine - no plastic at all on the bolts. Replaced the driver's side and the rattle is gone. Going to replace the other one tomorrow.
