Suspension
Old Oct 6, 2000 | 10:36 PM
dxplites's Avatar
dxplites
Suspension
I have a F250 S/D and the drivers side springs are noisey. Has anyone experienced such a problem? I checked the Service Bulletin and it refers to #6916.
Old Nov 15, 2000 | 08:28 PM
fatforty's Avatar
fatforty
Suspension
Old Nov 27, 2000 | 02:45 AM
believer45's Avatar
believer45
Suspension
I was browsing the site and came across your question. If it has not been answered yet, I had the same problem on both an '83 F150 and my current Ford '95 F250 power stroker, both on the left side. The problem was the lower shock bolt was loose. It would not turn and felt tight but it did allow the shock to shift a little bit side to side, just enough to make a noise on even the smallest bump. I put a breaker bar and socket on it and tightened it as tight as I could and the noise is gone. Hope this helps.
Dave
'95 Power Stroke F250 extended cab long bed 5 spd 99% stock - why try to improve on perfection?
