Bronco II Ford Bronco II
Emergency Brake Problem
Old Jun 5, 2004 | 08:56 PM
Aggie05's Avatar
Aggie05
89 bII 4X4, IM having problem with the ermegency brake cable, it has too much slack in the line, when i put the pedal down to the floor it doesnt get enough pull to engage back brakes enough... i tried messing with the nut on the tension thingy.. on the driver side. NO luck can someone tell me how to fix it or give me some direction.
thx in advanced.
Old Jun 5, 2004 | 10:19 PM
GrayRanger4x4's Avatar
GrayRanger4x4
First check the rear brakes.My e-brakes stop working on my 89 Ranger ,found out the rear brack where wore out {not metal to metal but real thin}.I reaplaced the rear brakes and the e-brake works like a top.JMO
Old Jun 7, 2004 | 11:31 AM
Aggie05's Avatar
Aggie05
I replaced them about 2 yrs ago, so hopefully i can get some time soon and pull the back tires off and take a look, ill let you know what i see.
thx again
Old Jun 7, 2004 | 04:35 PM
GrayRanger4x4
There aint much to the rear shose to begin with,and they dont coast that much.so if there getting thin replace them,if not ajust then and make sure that everything is working right.
Old Jun 7, 2004 | 08:47 PM
Ken00's Avatar
Ken00
The adjusters get gummed up and don't function properly, pay close attention to them.
Old Jun 8, 2004 | 03:39 AM
wolffpax's Avatar
wolffpax
When you say there was no luck at adjusting the equalizer; Did it adjust? I find mine freezes up over a period of time and you have to heat it up a little to get things moving. If that is what happening, try a little heat to free it up. If not I'd open the drums up, inspect the brakes, adjust the rear brakes, then re-adjust the E-brake tension. Make sure you are you don't over adjust and have them dragging on you. You just want the slack gone. Three to four clicks is what you usually want when applying the E-brake.
