390 to 300
Old Jun 5, 2004 | 08:39 PM
'73 250's Avatar
'73 250
390 to 300
I have recently bought a '73 F250 with a smoking 390 and tight C6 transmission. My dilemma is this, I want to rebuild (maybe build up) the 390, but I still need the use of the truck. I have access to a good running 300-6. I have swapped a 352 for a 300 before in a '64 I believe it was. This was for a friend, so I am not sure of the year. I built and welded the motor mounts in place while the engine was suspended from a crane. On my truck, I want to replace the 390 after the rebuild, so I need to hopefully get a set of motor mounts for a '73 F250 with a 300 6. Are these in existence? Any help or suggestions on the swap would be appreciated.
John
Old Jun 8, 2004 | 09:32 AM
Mike G's Avatar
Mike G
I know there are I6 trucks that I see in the salvage yard within that range, but keep in mind you can look for a truck from 73-79, they are the same. you will also need a tranny for that I6 as it will not have the same bell housing pattern as your 390.
--Mike
Old Jun 8, 2004 | 11:54 AM
78fordman's Avatar
78fordman
well, the 390 and the 300 have different bolt patterns. Both are great motors, but you would need a smf tranny for the swap and different towers.
Old Jun 9, 2004 | 03:31 PM
jpb222's Avatar
jpb222
the perches are actually the same for a FE and a 300 they just need moved one set of bolt holes forward or reverse (I forget which way)
Old Jun 9, 2004 | 08:25 PM
'73 250's Avatar
'73 250
Mike, the truck that I am going to get the I6 out of also has a good auto. trans. Thank all of you for the info.
John
jzedwick
15
Jul 17, 2011 12:12 PM
hotroddon
Engine Swaps
Jun 7, 2011 08:13 AM
abreiholz
Jan 19, 2011 05:16 PM
Widall
Nov 8, 2004 07:29 PM
