Need help
Old Jun 5, 2004 | 07:07 PM
stlthf1's Avatar
stlthf1
Need help
Guys....HELP.
I hit that stretch of road on Kellogg right before you get onto the north bound entrance to 235( full of pot holes). The truck jumped all over the place. The rear end went sideways a little. I made it up on on ramp and at the top of the on ramp the truck started cutting out. Then it died. I would start but sounding and felt like it was running on one cyclinder. I had my uncle tow me home. He mentioned it might be the fuel pump shut off switch. I found it and reset it. The truck now smells strongly of fuel but still won't start.
It either has to be fuel or ignition related. It will turn over great but just won't catch. I need to see if it's getting spark.
Any suggestions?
Old Jun 5, 2004 | 09:06 PM
nitro94's Avatar
nitro94
Jon, remove a wire and stick a screwdriver in it, hold it about a 1/4 in away from a ground source and crank it. You can call me tomorrow and I,ll help if you need it.
Old Jun 5, 2004 | 10:30 PM
scsmitty78's Avatar
scsmitty78
Just to make sure you might take out your chip. I know when they have a bad connection the engine wont run. Hope its something small and inexpensive.
Shawn
Old Jun 5, 2004 | 11:18 PM
stlthf1's Avatar
stlthf1
Lynn,
Can you send me your number again. I can't find it.
I put a screw driver in the first plug on the drivers side. I didn't have any kind of spark.
My first thought was after shaking the truck up so bad that the chip had fallen out or something. But when I checked it..it was still in very tight.
I need to find a rail pressure thing..LOL. I need to make sure I have fuel. I am almost sure that I do but who knows. I have a chilton's book that tells me how to check the coil pack. So that is another thing to check.
I'll probably pull the chip in the morning while the negative cable is off and reset the whole thing to stock. I wouldn't think the chip would cause an issue but....again...who knows.
I'm telling you...I was at Mel Hambeltons today and they had an 04' screw that was awesome. If I had the money I would have bought it today. SWEEEEET!!!
Thanks for the help,
Jon
Old Jun 6, 2004 | 08:52 AM
stlthf1's Avatar
stlthf1
So far I've taken the negative cable off and took the chip out. I reversed the install directions and it still won't start.
I left the negative cable off for about 5 minutes hoping it would reset the computer. Still doesn't work.
Chilton says it could be either Fuel or ignition related. Duhhhh...
There are a ton of test to find out if it's ignition. I can't seem to figure out if the ignition has a fuse. I've looked thru all the info but can't find one.
Jon
Old Jun 6, 2004 | 11:36 AM
fordborn's Avatar
fordborn
Jon,
Are you getting fuel pressure? On the fuel rail there should be a pressure check connection, it looks like a tire valve stem. Take the cap off and press down the core (be careful it should be under pressure) if no fuel comes out or it's not pressurized then you have a fuel problem. Most likely is the fuel cutoff switch.
Not sure about yours but mine has 2 fuses under the hood for ignition. #111 and 113 both are 40amp. There is also 1 in the drivers compartment #30 a 30amp.
Also you might want to post this in other forums to reach more people and help. There is the V-6 section or the 97-03 section. Lots of info out there and people that know more then I do.
Old Jun 6, 2004 | 12:12 PM
fordnut1985's Avatar
fordnut1985
Hey Jon, I have an OBD II scan tool if you need it just let me know. It might be able to point you in the right direction
Duane
Old Jun 6, 2004 | 12:55 PM
stlthf1's Avatar
stlthf1
I beat my head against the wall all night and all morning on what this could be. We were outside working on it trying to find this and that. Lynn pulls up....talk about happy.
He walks up to the truck. Looks at the engine and wiggled a wire. He said "try to start it". I got in the truck and it started right up....
A while back I was doing some of the wire loom covers. I had taken the wire off that gives power to the coil pack. I guess I hadn't gotten it on tight and when I hit that rough pack it knocked it loose.
So basically, I spent hours researching the problem and Lynn had it fixed and running in about a minute.
Lynn your the man and a heck of a member to the club.
Thanks very much. I told my wife he fixed it and she said if she was there she'd kiss him...LOL.
Thanks a million Lynn.
Jon
Old Jun 6, 2004 | 01:15 PM
scsmitty78's Avatar
scsmitty78
Glad it was somethings easy.
Shawn
Old Jun 6, 2004 | 04:43 PM
fordborn's Avatar
fordborn
Good to see you back up and running. Now don't drive it on the first saturday of each month. LOL
Old Jun 6, 2004 | 11:37 PM
Bargod's Avatar
Bargod
Man, the things that happen when I go out of town for the weekend.
Old Jun 6, 2004 | 11:44 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I know the feeling Jon. When I installed my e-fans I forgot to plug in the cold air sensor on my intake. It kept turning on the CEL light. I tried to figure it out. Spent atleast an hour on it. Finally took it to a friends shop. He pulled the code and the first words out of his mouth was "did you plug you cold air sensor bake in?" Doh! I felt like an idiot!
Old Jun 7, 2004 | 06:36 AM
stlthf1's Avatar
stlthf1
LOL...Rollie.
This is the second time Lynn's done this to me...LOL. But it's good to know someone that knows what he's doing.
Jon
Old Jun 7, 2004 | 06:43 AM
Peties3's Avatar
Peties3
Lynn, is the man!!! Way to go!!!!
Glad it all worked out for you Jon.
Mark
bobj49f2
Mar 30, 2014 03:06 PM
bobj49f2
Iowa Chapter
Mar 30, 2014 07:42 AM
pawpaw
1983 - 2012 Ranger & B-Series
Sep 25, 2012 10:02 AM
Walt_Mink
Oct 21, 2005 11:16 PM
fordnut1985
Kansas Chapter
29
Nov 4, 2004 08:29 AM
