1978 - 1996 Big Bronco
Engine died
Old Jun 5, 2004 | 12:15 PM
cwogaman's Avatar
cwogaman
Engine died
I was driving home from work last night and as I was pulling onto our street my engine just died. I put it in park and it fired right back up. Any ideas to what would cause this? I have an 87 Bronco with a 302.
Old Jun 6, 2004 | 06:46 AM
CLHAY's Avatar
CLHAY
Need more information about engine condition, miles, and any recent modifications.
When it fired back up were you able to get to your destination uneventfully??
Old Jun 6, 2004 | 11:56 AM
cwogaman's Avatar
cwogaman
The engine has 152,000 miles. I was able to make it home because it died when I pulled onto my street. So, I only had to drive about a block to make it. I have worked on it some in the last month. Last week I changed the distributor cap and rotor. The spark plugs were changed about three months ago, and I changed the water pump, heater core, and high pressure power steering line a few weeks ago. The only other modification I have is I have a K & N air filter.
A recent problem that I have had with it while driving is that it is lacking power while driving. It makes the truck surge some. I changed the plug wires yesterday because the last time this happened it was the plugs. I am about to take it for a drive, so I will see how it does.
Old Jun 7, 2004 | 08:34 AM
CLHAY's Avatar
CLHAY
Check timing, fuel pressure, and possiblt TFI!
