Aftermarket Products
Sponsored by: Worksport
Learn from my mistakes
Old Jun 5, 2004 | 06:36 AM
Blasko's Avatar
Blasko
Arrow Learn from my mistakes
I had a Rhino liner installed yesterday and while I like the lining the installation was barely adequate. The first thing I noticed was the Rhino tag glued to the front bed wall. I told the installer to remove it because I do not do advertisements. He warned me that wouldn't look good because it was stuck on with glob of silicone on the liner itself. Off it came. Now I will have to take a wire wheel to the glob and try to rough it up to blend with the rest of the lining.
I did not notice until I got home, the hanging drips under the inside front overhang that I will have to razor now .
Two lessons here. (1) Work out every detail in advance. (2) Check the work carefully before you leave!
Old Jun 5, 2004 | 01:04 PM
PW01's Avatar
PW01
Sorry to hear about that, but DON'T use a wire wheel, you'll ruin the finish. I would try using a chemical solvent, like a commercial "caulk remover".
Old Jun 5, 2004 | 03:54 PM
triton_2002's Avatar
triton_2002
If you took off the Rino tag, do you loose the warranty? Just curious.
Old Jun 5, 2004 | 09:14 PM
SoCalDesertRider's Avatar
SoCalDesertRider
The drips are normal, I have them on the underside of the bedrails on my Rhino Liner and have seen them on other spray in bedliners as well. Mine came with a small tag in the rear inner bedwall. I didn't mind it at all.
Old Jun 6, 2004 | 05:57 AM
Blasko's Avatar
Blasko
My receipt is proof of installation, I don't need thier advertisement for that
Old Jun 7, 2004 | 08:28 AM
TruckDaddy's Avatar
TruckDaddy
The low pressure/cold application liners, such as Rhino, produce drips and runs. High pressure/high heat application liners, such as LINE-X, don't have that problem.
Old Jun 7, 2004 | 10:57 AM
Blasko's Avatar
Blasko
Line-x was my first choice, but the only installer in my area went out of business.
Old Jun 16, 2004 | 12:38 PM
jasfaa's Avatar
jasfaa
I will never use anything but Line-x again. Wait until your handle brakes on the tailgate and you need to get in there. that one is really fun.....
Old Jun 21, 2004 | 03:58 PM
xallxforxchristx's Avatar
xallxforxchristx
The installer where I got my Rhino sprayed in did a good job in my opinion. I didn't notice until I got home that they neglected to put the Rhino tag on the bedliner. I meant to go back and get it, but have never made the time. It's not that big of a deal though, at least I know it's a rhino and that's all that really matters.
Old Jun 26, 2004 | 01:38 PM
gmcplus03's Avatar
gmcplus03
how has your spray in liners been holding up? am thinking about getting it done on my truck (04 f150) but was just wondering about quality and durablility. i could ask the dealers themselves, but they will only tell you what you want to hear.
Old Jun 26, 2004 | 02:54 PM
mike93's Avatar
mike93
i have "Line-X". had it installed 5 years ago and is holding up very well. even had a battery tip over and spill acid out and it didn't even affect the linner. "Line-X" appears to be a little thicker than the others.
Old Jun 30, 2004 | 07:28 AM
ssn randy's Avatar
ssn randy
beat mine BAD!!!
LINE-X
No damage to date, not even a scuff.
Randy
Old Jun 30, 2004 | 11:06 PM
tmyers's Avatar
tmyers
Concerning the tag, take it off after a few days and just pull the silicone off. Its what I did with mine and it was very easy to remove. With drips just take a razor blade and clean it up. I have never used Line-X so I can't comment on that product but In 10 years I have never had a problem with my Rhino linings. IMO though regardless of the brand if you use your bed hard both will wear. Still better than any drop-in ever invented.
