Aerostar Ford Aerostar
Power Steering Vibration
Old Jun 4, 2004 | 03:51 PM
DURSO's Avatar
DURSO
I have a '92 Aerostar EXT 4wd Eddie Bauer 108000 miles, and I notice that with the engine on when it is in park, or at a stand still if I turn the wheel from left to right, I have a vibration in the steering. Anyone else have this....Any guru's out there that can help me out with any possible problems/suggestions.
Any help is appreciated.
Thanks - Tony
Old Jun 8, 2004 | 08:40 AM
jasonbbq's Avatar
jasonbbq
Hello-I have the same van with a simular issue. I am assumming the rack or PS pump is at fault, because at a slightly higher RPM the vibration deminishes. Either the rack requires more fluid pressure or the PS pump can't generate the pressure at idle.
I've replace the belt and flushed the PS fluid when I purchased the van a few months ago and the issue is still present.
Sorry, I'm no help.
Good luck
jc
Old Jun 8, 2004 | 05:26 PM
capecodfc's Avatar
capecodfc
I had similar problems and used Lucas Power Steering Stop Leak. It stopped the leaking and smoothed everything out. It is only about $7.00. Worth a try. I was getting ready to swap the pump. That was 2 years ago. Still going strong with 190,000 miles.
T61066
Dec 3, 2006 09:53 PM
mchildress
Sep 16, 2006 10:58 PM
1985ColumbusF150
Oct 23, 2004 02:00 PM
ProfPaint
Aug 25, 2003 12:54 PM
Tony G
Electrical Systems/Wiring
Apr 19, 2003 12:04 AM
