94 Explorer upshift problem
Old Jun 4, 2004 | 02:07 PM
kensmyth's Avatar
kensmyth
Question 94 Explorer upshift problem
I've got an A4LD transmission that doesn't like to shift 1st-to-2nd or 2nd-to-3rd unless I take my foot of the gas. Thought I had found the answer in this forum with the vacuum modulator. I had ATF in the vacuum lines, so I replaced the modulator and the rubber parts that were loose. (didn't loose the steel pin either) Topped-off the fluid too but still have the same problem, except it seems to operate correctly for the first couple of shifts when it's cold.
I could probably go on shifting with my foot for another year, but I failed emissions because it didn't shift during the test. So I need to fix it or shoot it.
-Ross-
Sep 20, 2013 03:33 PM
73 fourxfour
Oct 14, 2012 10:35 PM
nlareau
Jun 16, 2011 06:10 PM
long&low65
Aug 11, 2007 09:19 PM
downhillpat
May 16, 2006 09:54 AM
