timing
Old Jun 4, 2004 | 11:22 AM
SVTYONE's Avatar
SVTYONE
timing
why is my firing order off by one all the way around.the truck runs great. it makes no sense. i was thinking timing chain. maybe skipped a loop.i bought the truck about 2.5months ago.i found that the distributor was loose and would constantly change timing on me. finally i got it tight and set timing. like above the truck runs great. i am going to pull the tc cover and put #1 to tdc and find wear the marks are and see if they are lined if they are than i dont know why the truck would run so good off by one.if it isnt than i am going to replace it with a gear drive from jegs or edelbrock
does sound like i am on the right path or is there a simpler way instead of tearing apart my motor.
Old Jun 4, 2004 | 11:44 AM
BB's Avatar
BB
Can't be the cam timing, if it was off the engine wouldn't run worth crap.
Soulds more like somebody stabbed the dizzy without the engine being at #1 TDC. Which way is it off, one ahead or one behind?
Old Jun 4, 2004 | 12:42 PM
Freightrain's Avatar
Freightrain
By "OFF by ONE", do you mean moving the plug wires around one spot it runs good??
No biggie, unless it really bothers you. If you want, rotate the crank to TDC and rotor pointing to the #1 wire(the one that runs good). Now pull dizzy and rotate the rotor until it points to the #1 on the cap. Now move the wires back to their proper spot. Ta Daaaa, you're now right on.
This is something that DOES NOT NEED TO BE DONE! But if it makes you feel better do it. It will run fine no matter where the #1 is on the cap. They just mark it to make it more uniform for everyone. Personally I think all my #1's are on different spots on every motor I have(since most have aftermarket dizzies).
If it runs fine...leave it.
Old Jun 7, 2004 | 10:01 AM
SVTYONE's Avatar
SVTYONE
this is what i was thinking. i am planning to convert to a gear drive for accuracy in timing.also will the timing be different from what the factory reads or will it run normal at factory settings.
Old Jun 7, 2004 | 10:26 AM
2ndmouse's Avatar
2ndmouse
dont all distributors run off a gear??
sorry you lost the greenhorn... lol
Old Jun 7, 2004 | 10:38 AM
gtex's Avatar
gtex
He is referring to a gear drive timing set. It replaces the timing chain with a set of gears that drive the cam instead of a chain. They sound really neat, but I have heard only bad things about using them on FEs. And ,I don't know anybody that is actually running one on an FE.
Old Jun 7, 2004 | 10:39 AM
led sled's Avatar
led sled
if you have an fe motor, those gear drives are quite expensive! also with the geardrives for the fe you can't run the mechanical fuel pump, you have to get a electric pump. a good double roller timing chain will be just as good if not better then a gear drive, for a quarter of the cost.
Old Jun 7, 2004 | 12:07 PM
Freightrain
I would leave a stock type chain in it(don't get one of those nylon set ups though). For a stocker, that is MORE than adequate for 100,000 miles of useage. $20 at your local autoparts store and you're set.
If you want to spend the $90 for a roller, do it, but it is not necessary. You will NEVER know the difference!! (only your pocketbook). Just my opinion.
As greg mentioned...gear drives for FE's are way expensive and by no means needed. Not sure of the fuel pump problem. The Milodon version I think would accept a pump cam on the front, but it takes machining to fit properly(not a driveway bolt on). I know the ol' Pete Jackson gear drive whine is cool and all....but the good ones DON'T whine(that's why they are much more expensive).
If the motor is pretty original and has +100,000 miles on it, then a new stock type chain will do you great. If someone has already put a chain in it,then I would assume it would not need another.
If you're expecting some great POWER gains from this....sorry, a gear drive won't do it.
Old Jun 8, 2004 | 09:58 AM
SVTYONE's Avatar
SVTYONE
i wasnt planning on power gain. i just wanted complete accuracy on timing.but from what ive seen here is that fes dont need them.i figured they would last longer than the chain and i like the mild whine. but i think i will get the double roller. thanks for all the info.this website is great
ford 300 f250
Apr 1, 2014 11:45 PM
Buyerz
Jul 29, 2013 07:31 PM
steventothemax
Feb 6, 2012 04:22 PM
manopause
Texas Chapter
Mar 9, 2005 09:27 AM
ITDave
Modular V8 (4.6L, 5.4L)
Sep 27, 2003 03:43 PM
