Bronco II Ford Bronco II
my big tune up
Old Jun 4, 2004 | 12:58 AM
raor386's Avatar
raor386
my big tune up
hey there everyone...been reading everything i can about the broncoII since i should be getting one pretty soon...its in kinda bad condition (horrible paint and the motor is acting up a little but ill get to that here in a bit...i was just wanting to see if my first big tune up (300 bucks max) was covering everything...here it is..
6 spark plugs at $6-----------$36-the quad fire "oh la la's"
wires-spark plug--------------$25
mobil oil filter---------------$10-im a mobil fan
mobil 1 oil------------5 quarts----------$15-im a mobil fan still
conrad cap and rotor kit---------$17-decent i think
honda type air filter---------$20-theres more to this and ill talk about it later
carb cleaner------------$8-clean things are nice
injector cleaner-----$8-always
oil pump----------------$60-these are a common killer so im gonna get one just to make sure
Actron Sun Super Tach 2-5/8" Black Dial Black Bezel------$35-i put one of these in every vehical i buy...just habit i guess
fuel filter------------$10-motorcraft
engine restore in a can---$10-i love ths stuff
ok i think that is it.....did i miss anything and do you recommomend other brands or what?????
i appreciate it alot....im a long time off roader and even longer time mechanic....
Old Jun 4, 2004 | 01:09 AM
raor386's Avatar
raor386
its an 88 im pretty sure...4x4.....2.9L...no lift....badly chipped paint....and does anyone know if i get a free repaint cause all the paint fell off....??????
Old Jun 4, 2004 | 01:32 AM
The Fish's Avatar
The Fish
First I would check out the stability of the engine (through compression and vacuum testing at least) before sinking big money into it. As for the paint thing I have the same problem with my 1989 Bronco EB, Ford said the recall ran for 3 years so we are out of luck. If you have another ride, check the local community (technical) colleges they will usually do it for material cost, the kids do a great job because they are getting graded on it, but sometimes it can take months to get done. It boils down to a time vs. money thing.
Old Jun 4, 2004 | 10:41 PM
GrayRanger4x4's Avatar
GrayRanger4x4
"mobil 1 oil------------5 quarts----------$15-im a mobil fan still" I would not use it on that old a veh,if it has a leak it will get worst and if it dont leak it will start.If you are a Mobile fan ues ther dino oil I think it called Molib drive clean 10W 30.
"engine restore in a can---$10-i love ths stuff"WHY?-If you got a compression proplem fix it dont just band-aid it.
"Actron Sun Super Tach 2-5/8" Black Dial Black Bezel------$35-i put one of these in every vehical i buy...just habit i guess" Why?- what is this and what does it Do??
"oil pump----------------$60-these are a common killer so im gonna get one just to make sure"IFyour going to replace the oil pump you might as well rebuild the engine you got to pull the engine to replace the oil pump anyway.JMO.
bismic
Mar 9, 2022 09:20 AM
1SAWB
43
Sep 4, 2018 06:32 PM
06FUN
Oct 29, 2016 07:53 AM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
megawatt00
52
Sep 25, 2012 06:01 PM
