cavitation/clutch
Old Jan 18, 2001 | 10:37 AM
sadsack's Avatar
sadsack
cavitation/clutch
I've gotten some good advise here in the past and now have
a couple questions.#1 Why is the cavitation problem more serious
with the diesel than a gas engine? and #2 Recently I had the
usual clutch release problem and replaced the whole release system,Both cylinders and connecting line.That cured the problem
but what was wrong with the old parts? There were no leaks,
fluid level was ok and I had already replaced the plastic bushing on the pedal to master cylinder.Couple mechanics at
garage couldn't answer-they just knew it worked.
Just curiosity. This is a 95 PSD F250. #####
Old Jan 18, 2001 | 03:07 PM
fordiesel69's Avatar
fordiesel69
cavitation/clutch
This may not be correct, but I read in a 4x4 magazine that the loud knocking polarizes the oxygen molecule into a boaring tool and eats through the liners. Cavitation is known on all diesels, but just not a problem to some makes of diesels. Ford and chevy tend to have this problem, but cummins does not. That is because cummins has sleeves and Ford/chevy's are part of the block. To prevent cavitation you should use Fords # FW-16 or Nalcool/Penray additives.
Check out this site: http://www.mstechinc.com/shopsite_sc/store/html/cooling_sys2.htm
Old Jan 22, 2001 | 06:13 PM
deleontow's Avatar
deleontow
cavitation/clutch
Cavitation is where the cyl wall will erode through from the coolant to the combustion chamber.
The problem with your clutch was probaly the master cyl. It may have been bypassing inside.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Jan 22, 2001 | 06:15 PM
deleontow's Avatar
deleontow
cavitation/clutch
fran35
Aug 26, 2016 06:23 PM
thordehr
25
May 19, 2016 09:17 AM
DukTruckin
Oct 15, 2015 07:48 AM
Rentaro
89
Jul 8, 2013 01:08 AM
jtannenba
1997 - 2003 F150
Jul 19, 2007 06:12 PM
