Cubic Inches
Old 01-07-2001, 05:18 PM
fatforty's Avatar
fatforty
fatforty is offline
Cubic Inches
Old 01-17-2001, 02:21 PM
canadianfordman's Avatar
canadianfordman
canadianfordman is offline
Cubic Inches
What are the cubic inches of the 6.9L and the 7.3L diesel engines. Thank-you
Old 01-17-2001, 02:47 PM
fordiesel69's Avatar
fordiesel69
fordiesel69 is offline
Cubic Inches
The 6.9 is: 420 cubic inch
The 7.3 is: 445 cubic inch
Old 01-17-2001, 02:55 PM
canadianfordman
Cubic Inches
Thanks for the help.
Old 01-20-2001, 10:14 AM
otto's Avatar
otto
otto is offline
Cubic Inches
i thought the 7.3 was 444 atleast thats what IH calls it on the hood of their straight trucks DT444E D being that its a "D Series" engine "T" being that its turbocharged and 444 being the cubes and "E" being that its electronically injected i may be wrong but im pretty sure to bad they didnt put the DT466E in the ford trucks thats one step better than that 444
Old 01-20-2001, 05:43 PM
fordiesel69
Cubic Inches
You are correct. There are two different 7.3 engines used in the fords. They are the 7.3 IDI(In-Direct Injection) that was offered in 1988 thru 1994.5. Then there was the powerestrokes offered that were basically DT444E but nick-named "Powerstrokes". The 7.3 IDI is 445 ci and the 7.3 Powerstoke is 444ci.
Old 01-22-2001, 06:01 PM
DannyP's Avatar
DannyP
DannyP is offline
Cubic Inches
I don't have a diesel, but I do have a question for you guys. What if any difference is there between the 445 and the 444 as far as block, crank, heads, etc. are concerned? I am curious as to what accounts for the 1 cubic inch difference. Any other info would be appreciated as well. My brother is considering buying a diesel and I am trying to get a handle on all this. From what I have gathered, the old IDI 7.3 is cheaper to work on than the newer one (someone said injectors were $3,000). Thanks.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old 01-24-2001, 05:29 AM
fordiesel69
Cubic Inches
Once again,
1988- 1994.5 = 7.3 IDI 445ci (in- direct injection) Old style, looks like a 6.9 but has 1/2 inch head bolts bigger pistons, and without a turbo from 1988- 1993. Can be identified by having a injector pump. Some time in 1993 they offered a factory turbo for the 7.3IDI and discontinued it in 1994.5. The 6.9's and 7.3 IDI's look almost identical and sound identical.
1995- 2001 = 7.3 444ci "Powerstroke" (Direct Injection) New style, totally electronically controlled. Different engine all together. Uses a high pressure oil system for injection operation. Very expensive to repair and most home mechanics can not fix them because of the expensive tools required. They sound very loud and can be identified by the loud turbochargers.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Cubic Inches
