What's The Difference???
Old Jun 3, 2004 | 06:14 PM
the_hetz's Avatar
the_hetz
1234567890
Old Jun 4, 2004 | 10:05 PM
kspilkinton's Avatar
kspilkinton
I think baumann engineering's site has the low down. Basically each is a redesign with other redesigns along the way. AOD is a non-electronically controlled four speed auto. The AOD-E is the electronically controlled version. The 4R70W is the redesign of the AOD-E. What's new with each? Someone else will have to tell you. If you have a 4R70W, it should work as long as the programming is set right for your truck.
-Kerry
Old Jun 4, 2004 | 11:53 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I think the 'W' stands for wide ratio, so it would have a lower first and second gear.
Old Jun 5, 2004 | 01:23 PM
kspilkinton
Yes it does So Cal. Some of the AOD-E's had wide ratio sets as well. That was one of the truck mods, but I'm pretty sure they put the AOD-EW's in Crown Vic's and other heavy bodied cars.
-Kerry
fontime
Feb 24, 2012 07:07 PM
a1bummer
Sep 27, 2010 04:27 AM
RaleighDad66
May 30, 2007 09:26 AM
aharrell
Mar 27, 2004 08:39 PM
rocky50
Jul 15, 2000 05:01 PM
