1978 - 1996 Big Bronco
damn wipers
Old Jun 3, 2004 | 01:45 PM
IllEatUrChevy's Avatar
IllEatUrChevy
Cool damn wipers
I have an 89 bronco. For the last couple of months the wipers when on start and stop after about 10 minutes of use. They will continue to go on and off unless I turn the switch off for about 5 mins. When i turn the switch back on they will run fine again for 10 mins and then go on and off again. This problem has been driving me nuts. Its not fun going down the highway doing 75-80 with the wipers acting up on a rainy day. ANY HELP WILL BE MUCH APPRECIATED. Thanks in advance.
Old Jun 3, 2004 | 03:40 PM
fcarruth's Avatar
fcarruth
Sounds like the motor is going out. When it gets hot it will basically die and once it cools down, it will start back. Get your Haynes manual out and verify some voltage, check the fuse or just make the swap.
Good luck,
phoneman91
64
Feb 2, 2025 05:40 PM
RIKIL
Oct 4, 2015 11:44 AM
David40
Feb 22, 2015 06:20 AM
Tony_C
Sep 10, 2011 09:17 AM
evan250
Sep 12, 2004 09:01 AM
