Need help with Pertronics hookup.
Old Jun 3, 2004 | 11:38 AM
6t6merc's Avatar
6t6merc
I've removed the Pertronics Ignitor ll during an engine change, and I've forgotten how to reconnect it. I seem to remember that there's something different about it. Can someone help me out before I melt this thing? Thanks.
Eric.
Old Jun 3, 2004 | 06:55 PM
cdherman's Avatar
cdherman
The red wire needs 12v. The black wire goes back to the "neg" side of the coil.
IF you have stock coil, you cannot use the "+" terminal on the coil for the Pertronics, becuase it is getting 8v due to the resistor wire in the lead under the dash. In the case of useing a stock coil, a new sounce of 12v is needed for the Ignitor unit -- suggest running new wire from switch under dash.
If you are using a aftermarket coil such as Flamethrower etc you can give it the full 12v. In which case, you can get your 12v for the Pertronix from the "+" side of the coil. But you will have to either remove the ballast resistor wire, or run a new lead direct from the switch so BOTH are getting 12v.
Make sense? Probably not, but I tried to cover both possibilities that you may confront.
Old Jun 3, 2004 | 11:56 PM
6t6merc's Avatar
6t6merc
Yup, it does make sense. I recall now that what's unusual is that the distributor has two wires coming out of it. We fire up the new 352 tomorrow!
Thanks, cd.
Eric
