360 tbi?
Old Jun 4, 2004 | 04:35 AM
Darvit's Avatar
Darvit
360 tbi?
HI all qwik ? I have heard that a dare I say it , Chevy 350 tbi can be used for tbi setting on a 352 since the 352 and 350 are close in CID, will it work for a 360? And for those that read my other posts My dads friend chose not to take the '65 flatbed so we now have a 65 and 66 to work on.Dad also managed to get a GMC s15 ext cab out of the deal so now i need to fix up 3.
Old Jun 4, 2004 | 08:43 AM
Mike G's Avatar
Mike G
A TBI system can be used on any motor, if you wish to take that route. As far as the GM system, I doubt it, not a swap over item as the TBI, at least for the early systems, did not have the regular 4-bolt type mounting to the manifolds.
JMO --Mike
Old Jun 4, 2004 | 08:44 AM
scamardo's Avatar
scamardo
Won't work. The FE will recognize the Chebby part and throw it through the radiator.
Old Jun 4, 2004 | 09:13 AM
FordBoypete's Avatar
FordBoypete
All BrandX EFI's are resistence based, harness type, wires size and constant voltage supply, sensitive Cr*p. Central Fuel Injection, or what you are calling Throttle Body is little more than a overly complicated carburetor without a needle & seat, float bowl, or jets, which does not work well, & often works worse than a carb.
The deal with EFI is tuned port injection, Mass air flow, something more advanced than Speed Density Logic in the O/S and it should improve, not detratct or degenrate performance and efficiencies of what ever it's put on.
I dislike carburetors but as much as I like EFI, I'd run a carburetor forever before I'd put a Central Fuel Injection (no gain) system on anything. Why complicate your life with documentable & certified junk?
Just my opinion on the matter.
FBp
