Eec-iv
Old Jun 2, 2004 | 11:17 PM
GEugeneS's Avatar
GEugeneS
Eec-iv
Trying to convert to MAF on a 91 F350 7.5 but I can't even find the old EEC-IV. Could someone clue me in where it's located. I have been told passenger side kick panel (not there). But I saw a box close to the size of the replacement EEC in the middle under the dash, but the connector is way too small.
Your help would be appreciated.
GEugeneS
Old Jun 3, 2004 | 03:48 PM
Franklin2's Avatar
Franklin2
The Powertrain Control Module (PCM) is usually located under the instrument panel or passenger's seat and is usually covered by a kick panel. A multi-pin connector links the PCM with all system components. The processor provides a continuous reference voltage to the B/MAP, EVP and TP sensors. EEC systems use a 5 volt reference signal. Different calibration information is used in different vehicle applications, such as California or Federal models. For this reason, careful identification of the engine, year, model and type of electronic control system is essential to ensure correct component replacement
PCM's for EEC-IV systems use a 60-pin connector. For the EEC-V PCM, a 104-pin connector is used.
Old Jun 5, 2004 | 10:59 AM
GEugeneS's Avatar
GEugeneS
So what you are saying is the PCM and the EEC-IV is the same thing?
Old Jun 5, 2004 | 10:01 PM
Franklin2's Avatar
Franklin2
Yep. I just copied and pasted that blurb from a manual. Sounds like it's under the dash or under the seat.
Old Jun 5, 2004 | 11:44 PM
Racerguy's Avatar
Racerguy
It's behind the park brake pedal.
The connector is on the engine side of the firewall.
lildrummer420
33
Nov 28, 2023 03:36 PM
Unaffiliated
Oct 13, 2016 09:13 PM
Patrick Omally
15
Sep 25, 2014 11:42 AM
mike L
Jan 23, 2010 10:08 AM
bones68
Bronco II
Mar 8, 2007 07:07 AM
