First oil change question
Old Jun 3, 2004 | 03:48 PM
supernewguy's Avatar
supernewguy
I'm confused
okay, maybe this is correct then.
Ford uses lighter oil for break-in. Ford then uses heavier oil for normal operation starting from 1st oil change. Could this be why people notice a drop in mpg's after the first oil change? and possibly confuse a loss to a reflash? After sending my scmt in and reloading the stock program, I can see a big difference in my mpgs around town. I initially loaded the scmt right after my first oil change and was driving it around until I got tired of the harsh shifting at lower speeds in econ mode.
Old Jun 3, 2004 | 04:14 PM
twoballsleft's Avatar
twoballsleft
supernewguy-.....Hmmm....could have something here. 750mi on her now so I'll know in about 2500 miles when they change the erl, ha!
Old Jun 3, 2004 | 10:53 PM
supernewguy
Originally Posted by SBV45
Get a Fumoto valve http://www.fumotovalve.com. You won't spill a drop and change it your self. Do a search. Instructions on changing oil has been posted here and is in your owner manual.
Is the F-111 with nipple the correct one?
thanks
Old Jun 4, 2004 | 12:20 AM
supernewguy
Finally found it. Yep F-111 with nipple (ordered it already). My only concern is no magnet like on standard drain plug. Maybe I should wait and put a few more miles on her. What do you think? i currently have about 4500 miles on the odometer. Also, finally read through the "oil" thread and the oil-guard kind of interested me. I'm not real mechanically inclined and psdwannabe's pics of his install are no longer posted.
Old Jun 4, 2004 | 05:34 AM
SBV45's Avatar
SBV45
On my first oil change, I had little fuzz on the magnet on the drain plug. Second oil change, there was a trace. I then put on the fumoto and don't worry about it. I changed at 3600 and 7500 and 11,000.
Old Jun 4, 2004 | 06:15 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Does anyone worry about getting the lever hit or someone flipping it.
Restlesswildman
Sep 1, 2013 04:58 PM
bill11012
Modular V10 (6.8l)
20
Nov 25, 2009 06:14 PM
zillah
Oil & Lubrication
Jan 23, 2009 09:17 PM
ronxp2000
1997 - 2003 F150
22
Apr 1, 2004 09:00 PM
tradingden
Oil & Lubrication
Dec 3, 2003 05:22 AM
