TIE ROD!!
Old Jan 18, 2000 | 03:31 PM
RickK's Avatar
RickK
TIE ROD!!
Old Feb 14, 2001 | 09:36 AM
ford4x4offrd's Avatar
ford4x4offrd
TIE ROD!!
What is the best way to see if a tie rod has outlived itself. when ever i get out of 3rd into 4th my front tires start to wobble so bad i have to pull over and completely stop than go again. i shook the tires up and down, left and right, and everything is tight. but the ends of the tie rod looks all worn. its a '89 F350 7.3L the other tie rods are replaced but this one is original. any help would be appreciated. thanks
-Jacksland
Old Feb 14, 2001 | 04:12 PM
fordiesel69's Avatar
fordiesel69
TIE ROD!!
Very simple, have someone turn the steering wheel left and right and watch all the joints. Make sure the engine is running.
Old Feb 14, 2001 | 04:41 PM
ford4x4offrd
TIE ROD!!
As i look at the joints, what am i looking for. play in them? just need a little more guidance, thanks
Jacksland
Old Feb 14, 2001 | 05:20 PM
powerstroker1234's Avatar
powerstroker1234
TIE ROD!!
Have the balance checked on the tires. I had a set one time that were so out of balance that I couldn't keep it on the road much less get over 30mph. I had the steering linkage checked and everything was fine. It was the tires out of balance. I didn't think tire balancing could get that bad but it did!
Les
Old Feb 14, 2001 | 08:07 PM
ford4x4offrd
TIE ROD!!
Yeah i work in the auto center at a sears, and thats what the first thing i checked was. they are 35x12.50x16.5 and they are balance to within .25oz so i dont believe that the balance is the problem. like i said the one tie rod that goes across the whole front is the only thing that is still stock. there looks like there is some play in the ends, so i am assuming thats what it is, but more suggestions will help. thanks
Jacksland
Old Feb 15, 2001 | 03:01 PM
powerstroker1234
TIE ROD!!
If there is play in the tie rod as you say then I would replace it then have the toe adjustment done.
Les
Old Feb 16, 2001 | 08:22 AM
ford4x4offrd
TIE ROD!!
Replaced and vibration gone!!!! but align is so far out, all i can do is laugh. now just to find an alignment machine for 35x12.5x16.5! thanks for all the help. where are you guys all from? just to put name and place together, im from upstate NY
-Jacksland
Old Feb 16, 2001 | 01:24 PM
powerstroker1234
TIE ROD!!
Glad you got it fixed. I had mine aligned with 12/33's on it.
Reno, Nv.
Les
Old Feb 17, 2001 | 01:10 PM
ford4x4offrd
TIE ROD!!
I am having a difficult time finding someone to align it. if i put stock size tires on it just for the alignment and then put the 35's on after, will that affect the align. basically is it worth it? thanks
-Jacksland
Old Feb 17, 2001 | 08:25 PM
jeepnford's Avatar
jeepnford
TIE ROD!!
If you can't find anyone to align it with the large tires,put the stock size on it then get it aligned. Since all they set on 4x4s is the toe-in,it would still be very close to being correct.
Old Feb 17, 2001 | 11:31 PM
ford4x4offrd
TIE ROD!!
Thanks for the help! ill do that than. thanks again, take it easy
-Jacksland
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
