tires
Old Mar 2, 2001 | 08:14 PM
powerstroke man's Avatar
powerstroke man
tires
What's the largest tire I can install on a F-350 dually? Truck came with 235/85/16 10 ply tires and I don't want to add spacer to dual wheels to accommodate larger tires. If the spacer is the only option then include information in your response.
Old Mar 3, 2001 | 09:36 AM
fatforty's Avatar
fatforty
tires
Hi, the 235/85/16 is about the biggest tire you can get on the truck without spacers. I put 265/75/16 on one and when you put a load on it the tires rub together had to change them they will build up heat from rubbing together which will cause tire failure. John
Old Mar 4, 2001 | 04:37 PM
The Diesel Dude's Avatar
The Diesel Dude
tires
