Sponsored by: Real Truck
Cop Problem Again
Old Jun 1, 2004 | 03:07 PM
Hotshoe's Avatar
Hotshoe
Cop Problem Again
This problem never ends! When ever it rains and i'm running logging roads with the 5.4l for my work, we loose a coil.The rear passenger coil is a bi PITA to get at.Ford needs to do something about it.14 coils in 140,000 KM.I know this gets beat to death but is anyone else experiencing these quantity of problems?
Old Jun 1, 2004 | 03:22 PM
Big Orn's Avatar
Big Orn
I don't know if I personally have addressed this problem here, but here's my opinion:
There has to be a problem other than the coils themselves. There could be a seating problem with that rubber boot on the head (plug cavity). Do you coat it good with dielectric grease before you install it? Have you checked for breaks, tears, cracks, and/or "spark marks" (those small burned areas)? What about the electrical connectors? Are they sealed?
There are many ifs, ands, and buts, but there has to be something about your engine exclusively, or your setup.
It is a strange situation, though.
I haven’t experienced that sort of thing, myself.
Old Jun 1, 2004 | 03:58 PM
Hotshoe's Avatar
Hotshoe
My dealer mechanic says ,that it's all the vibration & dirt the motor is getting is the trouble.He said that it's a poor design for a guy like me.Makes the truck run rough as hell till it gets home.I worry about loosing a cylinder.
Old Jun 1, 2004 | 04:10 PM
Big Orn's Avatar
Big Orn
You must really get down and dirty out there, Hotshoe.
But, there's got to be another explanation. My youngest son puts his 5.4 through the worst gunk I’ve ever seen. He’s never had that kind of trouble. You can’t even see the coils sometimes.
Maybe someone that’s experienced this will come along with a better explanation, but right now I’ve got to stick with the boots and/or connectors not sealing as being the problem.
Old Jun 1, 2004 | 04:27 PM
Hotshoe's Avatar
Hotshoe
Big Orn,thanks for your info. I use motorcraft parts every time,maybe there is a better aftermarket?
Old Jun 1, 2004 | 04:42 PM
Big Orn's Avatar
Big Orn
No, I don't think so. But, I'm still not convinced it's the coils. Do you replace the boots each time, or at least inspect them closely? It's hard to see the defects with the naked eye.
Old Jun 1, 2004 | 05:03 PM
Hotshoe's Avatar
Hotshoe
New coil sparkplug boot unit & Dielectric grease every time.
Old Jun 1, 2004 | 05:11 PM
Big Orn's Avatar
Big Orn
In that case, I'll have to think on this one awhile...
Anyone else have an idea?
Old Jun 1, 2004 | 06:14 PM
99f350sd's Avatar
99f350sd
I used those wheel well protectors to keep the junk out they work real well...
https://www.ford-trucks.com/forums/s...52B%25252Bwell
Old Jun 1, 2004 | 10:31 PM
02superstroker's Avatar
02superstroker
I thought the coil springs wern't coming in until 2005!!!
I hope ya know I was kidding...
Old Jun 1, 2004 | 10:42 PM
wlihntr's Avatar
wlihntr
i am still trying to figure out why it is a cop problem, i thought he was in trouble with the law
Old Jun 2, 2004 | 06:15 AM
slc10844's Avatar
slc10844
Sounds like water migrating into the spark plug cavity. I've had it happen when cleaning the engine. Water seems to collect in the rear hole. You might try putting a small bead of silicon sealant around the top of the boot where it meets the flat of the cylinder head to see if it helps.
Old Jun 2, 2004 | 06:28 AM
Hotshoe's Avatar
Hotshoe
It was #7 this time. I got her back .Yep it's pouring again today and i got to make 300km run on dirt logging roads .
Old Jun 2, 2004 | 09:22 AM
Big Orn's Avatar
Big Orn
I take from your post, I got her back, that you had this done. Did you get a chance to observe the replacement procedure? I was thinking: There is a small brass bushing on the COP flange that stops the attachment screw from distorting the seal when tightened. Maybe there's a burr or deformity in that area that prohibits the rubber from sealing around the plug cavity?
In my way of thinking, there has to be something allowing water/mud to contaminate the coil connectors - either at the spark plug contact or at the outer electronics area.
Old Jun 2, 2004 | 03:15 PM
Hotshoe's Avatar
Hotshoe
No problems today.
Anyone have a pic of the wheelwell protector installed?I ordered a pair.If it works i'll be putting them on the rest of the Super Duties.The F150 already had some.I never noticed them before.
