Sponsored by: Real Truck
Cop Problem Again
Old Jun 2, 2004 | 03:23 PM
Hotshoe's Avatar
Hotshoe
Originally Posted by Big Orn
I take from your post, I got her back, that you had this done. Did you get a chance to observe the replacement procedure? I was thinking: There is a small brass bushing on the COP flange that stops the attachment screw from distorting the seal when tightened. Maybe there's a burr or deformity in that area that prohibits the rubber from sealing around the plug cavity?
In my way of thinking, there has to be something allowing water/mud to contaminate the coil connectors - either at the spark plug contact or at the outer electronics area.
I did not see the install. i"ll mention it next time.I'm sure i'll be getting it done sooner or later again.
Old Jun 2, 2004 | 07:09 PM
92f150I6's Avatar
92f150I6
In my shop, this is a fairly common occurence on these style coils. The older ones with plug wires seem to be much more relyable. The boots get old and crack, which leaks spark energy to ground.
Old Jun 5, 2004 | 08:21 PM
LilBlackCoupe's Avatar
LilBlackCoupe
I would question something else... not istallation procedure. Measure voltage going to each coil and make sure that they're all the same. Next time it happens, move another coil to that spot and put the new one in its place. See how long it takes to go bad. Makes no sense that the same one keeps going.
Old Jun 5, 2004 | 08:31 PM
fast250r's Avatar
fast250r
antifreeze is my problem
I have been having misfires on the passenger rear COP. My issue is antifreeze in the COP/sparkplug hole. If I blow it out with air and change the plug it runs fine. But it always returns. First I was told it was from a heater hose located above the hole. I checked, that wasn't an issue. I checked the TSBs and found one that said there is an issue with certain 5.4s that occasionally leak antifreeze from the intake gasket. I am replacing the gaskets tonight. I'll let you know if it made a difference.
Mike
http://www.alldatadiy.com
handell35
2004 - 2008 F150
Apr 29, 2013 02:37 PM
apalo187
Escape & Escape Hybrid
May 5, 2010 08:56 AM
53redford
Dec 13, 2007 04:51 PM
Greer
New Member Introductions
Oct 28, 2007 08:32 PM
