Fuel gauge problems
Old Jun 1, 2004 | 02:23 PM
KB ZILLA's Avatar
KB ZILLA
Fuel gauge problems
I have seached this board and many others and still I am not sure where I should start.
My 93 F150 has a gas gauge problem that has me baffled.
The gas gauge reads empty when the selector switch is in either position.
I have only had the truck for a week, and have only used the front tank.
I dont know if both tanks pump or not, I have flipped the switch to the rear tank and the truck stays running, but I dont know if it is actually running off the rear tank or not swapping tanks and still running off the front.
Old Jun 1, 2004 | 06:37 PM
acerockola77's Avatar
acerockola77
So it dosen't register on either tanks?
I wouldn't be suprised really. The sending units on the gas gauges go bad quite frequently.
Old Jun 2, 2004 | 04:51 AM
KB ZILLA's Avatar
KB ZILLA
My next move is to check the wiring at the back of the selector switch. Then drop tanks and check floats
Old Jun 2, 2004 | 01:18 PM
wtroger's Avatar
wtroger
There is a fuel pump test port on the ecc test plug. Get a pin out diagram of this plug and plug a wire into it then turn on the ignition and ground the wire. If you disconnect the high pressure pump on the frame rail you can hear the pumps run in the tanks move the tank selector and the corresponding pump should run. And yes the chances are good that both floats are bad.
Old Jun 2, 2004 | 05:09 PM
sglaine's Avatar
sglaine
Posting Legend
I found with my old truck pounding on the dash works. The same goes for the oil presser gage too.
