rough idle
Old Mar 3, 2001 | 08:16 PM
enulsen's Avatar
enulsen
rough idle
Hi, I'm looking at a 1995 F250 with the 7.3L diesel with manual transmission. It will run very rough for approx. 15 seconds if the engine is loaded slightly at idle and then the load released. Any ideas?
Thank You
Enulsen
Old Mar 4, 2001 | 03:57 PM
ben towe's Avatar
ben towe
rough idle
My 1997 F-250 PSD does the same thing,if you rev it up (especially cold) and let off it's real rough right?Mine too.
Old Mar 4, 2001 | 04:28 PM
The Diesel Dude's Avatar
The Diesel Dude
rough idle
Sounds like a case of oil aeration to me. Either try changing the oil with Motorcraft (the stuff Ford recommends) or Shell Rotella (I'm sure there are other oils that meet the Ford recommended requirements but these are the ones I know do) or go to a Navistar dealership and ask for the anti-foam oil additive and see if that helps.
Old Mar 9, 2001 | 09:13 AM
ford4x4offrd's Avatar
ford4x4offrd
rough idle
My '89 7.3L has had nothing but kendell 10w40 from napa. had good luck with it, but when you change the oil i would def. pay a little extra for the good stuff. good luck
-Jacksland
Old Mar 9, 2001 | 01:23 PM
The Diesel Dude
rough idle
On a cold engine there is, in the exhaust system, a "back pressure device" (similar to a Jake Brake) that is designed to close to facilitate warm-up faster. If this roughness you discribe is only happening with a cold engine, it could be this back pressure device is in the "on" position.
Old Mar 12, 2001 | 12:30 PM
enulsen's Avatar
enulsen
rough idle
Thanks for the info.
Old Mar 13, 2001 | 06:02 PM
barno's Avatar
barno
rough idle
cnichols
1997 - 2003 F150
Apr 15, 2012 02:35 PM
steamboatjr
1983 - 2012 Ranger & B-Series
Jun 12, 2009 06:10 PM
ckgentry
Modular V8 (4.6L, 5.4L)
Dec 28, 2003 11:03 AM
dvlinnell
Apr 16, 2002 11:29 PM
matt davis
Feb 15, 2001 03:10 AM
