overheat?
Old May 31, 2004 | 11:12 PM
psycocrazy's Avatar
psycocrazy
overheat?
ok, evrything works on my truck, right?
check this..... when i turn on my a/c, 2 things happen.
1 my temp gauge climbs to right at the 'hot' level and
2 my oil pressure gauge goes to 'high'.
i already checked the water and oil levels, recently changed the thermostat and water pump and valve cover gaskets and radiator. any thoughts? it runs fine, i just dont want to crack the heads like i did on my last motor.
thanx
Old Jun 1, 2004 | 11:04 AM
'04 4.0 XLT's Avatar
'04 4.0 XLT
Are you talking an instantaneous spike, or a gradual rise? If the moment you turn the AC on the gauges spike, it's probably and electrical malfunction.
Old Jun 1, 2004 | 08:09 PM
Ken00's Avatar
Ken00
Does it run hotter at slow, fast or both speeds. Whats the history of your cooling system?
Old Jun 2, 2004 | 01:08 PM
psycocrazy's Avatar
psycocrazy
it runs hotter at both fast and slow... the history is that ive put replaced just about everything but the condenser, but im not sure if replacing that would help. heater core, radiator, thermostat, waterpump, and top radiator hose have been done pretty recent.
Old Jun 2, 2004 | 03:09 PM
87 XLT's Avatar
87 XLT
Strange problem. If this was my 87 i'd try removing fuse 9 (AC clutch switch & blower motor) & see if the gauges still act crazy. Sounds like some sort of electrical problem with the gauge.
Old Jun 2, 2004 | 03:39 PM
Ken00's Avatar
Ken00
Could you answer 04's question?
Old Jun 3, 2004 | 01:13 PM
psycocrazy's Avatar
psycocrazy
the temp change usually takes about 2 minutes
Old Jun 3, 2004 | 01:53 PM
87 XLT's Avatar
87 XLT
Flush the condensor/radiator from the engine side with a garden hose. Not too much pressure, the cooling fins can bend easily.
Old Jun 3, 2004 | 08:06 PM
Ken00's Avatar
Ken00
If that doesn't help you radiator might be clogged internally.
Old Jun 3, 2004 | 10:13 PM
psycocrazy's Avatar
psycocrazy
i sincerly hope my radiator isnt clogged. ill try to flush it tomorrow if i have the time. darn maybe ill have to drive dad's car.....
Old Jun 4, 2004 | 06:20 AM
pawpaw's Avatar
pawpaw
Did these problems begin before you did all this work????
What event preceeded the guages acting up????
On the coolant temp thing, I hesitate to ask this, but are you certain you didn't install the thermostat backwards, if it can be done so, on your year/model??
When you replaced the radiator, was it with the same sized one????
I noticed you replaced the top radiator hose but not the bottom one.
Are you shure the bottom one isn't soft & collapsing some & restricting coolant flow.
On the oil pressure rise, did it occur at the same time the coolant temp guage began acting up???
If not, what event preceeded it's acting up???
We may have two separate problems here.
Old Jun 5, 2004 | 03:40 AM
psycocrazy's Avatar
psycocrazy
ok new thing ive noticed.
when the a/c is on and everything is going wierd, when i turn the a/c completely off and the temp gage settles back down, as does my oil pressure gage. not sure if that means somethin or not. i just noticed this tonite, when i was on my way to a friend's graduation.
pawpaw-
both problems happen at the same time. i checked all the hoses, i know the thermostat is in correct because i watched a mechanic friend do it at the same time he did the water pump. the water pump and radiator are original replacement parts. anything else?
Old Jun 5, 2004 | 10:50 PM
pawpaw's Avatar
pawpaw
Well as you desribe it, sounds like the guages behave normally until the AC is switched on, is this correct???
The engine isn't really overheating, correct???
Did this guage problem begin BEFORE all this work was done????
Why were the radiator, water pump & upper hose replaced???
Old Jun 7, 2004 | 12:02 AM
psycocrazy's Avatar
psycocrazy
it hasnt really overheated yet, i just dont want to crack the heads again. and this is a recent problem, 1 month after water pump and hose replacement, about 6 months after radiator replacement. and it only does it when i turn the ac on high. replaced the radiator cause it was blocked about halfway down, and the waterpump was starting to go out, so i got a mechanic friend to do it while i watched.
Old Jun 7, 2004 | 01:21 PM
pawpaw's Avatar
pawpaw
Ok, only does this when you have the AC on "high", does this mean having the blower motor speed switch on high??
If you put the blower speed switch on lower settings, are things ok????
Will the guages act out if you turn the blower motor speed on high, while in, say the vent, or heat mode???
Will they act out if you're in defrost & low or high fan speed???
