Blowing fuses
Old Mar 13, 2001 | 09:41 PM
pwrstrker's Avatar
pwrstrker
Blowing fuses
I just bought a 1995 F-350 crewcab with PSDiesel/ 120,000miles. As I was driving down the road, the engine shut down as if the gas supply had been turned off. The ignition was still on. I stopped and it would fire but would turn over. It was found to be a fuse from under the hood that blew. Two days later, it blew again. Then the third time, it blew as i was about to start it. Same fuse every time. Fuse #22 under the hood. Just a short do u think? or something else.
Thanks for any help.
Old Mar 13, 2001 | 10:55 PM
killer4x4's Avatar
killer4x4
Blowing fuses
I would think it to be a short. Or two ires are coming or have rubbed off on each other and sometimes touch then blow the fuse. Does it blow it when you start it? Or just driving down the road?
1985 "Cowboy Cadillac" Ford F-250 4x4, Granny 4-speed, 4:10 Gears, 460 with Holley 750cfm 4-barrel Carb, Custom Painted Block (Ford Dark Blue), Rebuilt Transfer Case, BFG Trac-Edges, Tachometer, Kenwood CD Player and Pioneer Speakers, 27" cherry bombs dualed out each side with 2 1/2 inch pipe, NAPA Premium Clutch, NAPA Premium timing Chain, Gooseneck Ball, Hitch Reciever, Whistler 400 radar detector!
"When in Doubt GAS it"
Old Mar 14, 2001 | 07:34 AM
pwrstrker's Avatar
pwrstrker
Blowing fuses
It has done both...first two times was while going down the road...the third time was as soon as i turned the key to start it and it blew immediately.
Old Mar 14, 2001 | 08:39 AM
ford4x4offrd's Avatar
ford4x4offrd
Blowing fuses
Definitely sounds like a short. check all the wires is th eonly thing you can really do. good luck
-Jacksland
Old Mar 16, 2001 | 07:03 PM
mr ih's Avatar
mr ih
Blowing fuses
[font size="1" color="#FF0000"]LAST EDITED ON 16-Mar-01 AT 08:04 PM (EST)[/font][p]my fuel heater went bad on 96 f250. It kept blowing that fuse. Just a thought. Filter hsg & heater are one in same.
Old Mar 16, 2001 | 09:04 PM
pwrstrker's Avatar
pwrstrker
Blowing fuses
As a matter of fact...it was the fuel heater!! Just found out two days before ur reply but thanks anyway. Apparently a common glitch...Thanks for the info
Old Mar 18, 2001 | 02:09 AM
The Diesel Dude's Avatar
The Diesel Dude
Blowing fuses
